Results 1 to 9 of 9
  1. Hello,
    What x264 encoder settings do you guys recommend for the best balanced quality when I want sharing on youtube, i'm talking here about settings like gop, b-frame, resolution, tune/present/mode crf/resize method? Currently I use pioneer dvr 560 (xp+ mode) to capture pal source, after cutting I use "Hybrid" (QTGMC) crf 15, crop - 8 -8 left right, target resolution 960x720, output par square pixel 1:1.
    Thank you for all voice.
    May 2005
    Australia-PAL Land
    If you make it 1920x1440 (the 1440 is the important part) YT will encode your video in VP9, better than AVC/H264.
    If it's fairly short, I'd export as AVI lossless and give that to YT. No point in encoding it H264 then having YT re-encode it. I've been known to upload ~4GB AVIs to YT.
  3. Interesting and not bad idea, anyway if someone has any other ideas I will gladly listen.
  4. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    https://forum.videohelp.com/threads/409707-Youtube-Workflow (I was just replying in this thread, you may find additional infos there)
  5. For uploading VHS PAL footage to YouTube:
    Resolution: 640x480 or 720x576 (SD) or 1280x720 (720p)
    Frame Rate: 25 fps
    Codec: H.264 (MP4 container)
    Bitrate: 2,500 - 8,000 kbps
    Audio: Stereo, 44.1 kHz or 48 kHz (AAC/MP3)
    Consider basic color correction and deinterlacing
    Provide clear title, description, and tags
  6. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Frame Rate: 25 fps
    Same bad guidelines as in https://forum.videohelp.com/threads/410916-IVTC-using-TFM-or-Handbrake-Is-there-a-qual...=1#post2702589
    Still experimenting with ChatGPT?
    May 2005
    Australia-PAL Land
    Samson Stages, those are VERY basic parameters for the un-educated. "Consider basic color correction and deinterlacing": seriously?
    Those resolutions and bitrates should be considered as the minimum; YT will take much more, as I assume you have seen in the posts above, that will improve quality.
  8. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Alwin, he's just trolling
  9. oki thx for link.
