The problem : youtube video with an acceptable quality in your mother language will be not present on youtube, but the same film in a foreign language and with a better quality will be present, e.g.: Citizen X
https://www.youtube.com/watch?v=d-vtFmNfmOw&pp=ygUJY2l0aXplbiB4, german with additional Documentation, the film itself 1:36:00, bad video quality
https://www.youtube.com/watch?v=xVIeqyZtuDk&pp=ygUJY2l0aXplbiB4, french, 1:40:00
Both films cut with Avidemux at the "same" position (nearest position, depends on the respective IDR Frame), to have the same basic.
1. Got with ffmpeg audio only of the german film, video only of the french
2. Stretched with Audacity the audio-only stream, to have the same length as the french film, video only.
3. With ffmpeg merged the "french-film" and german-audio
4. Load the merged film with Avidemux and did correct the audio-offset.
Did check the film until the synchronization will be lost, go back to the last synch. part, and did cut the rest, saved as CitizenX1.
Load again the film with Avidemux to find the next audio offset for the second part of the film, a.s.o..
Is there a better way (tool, Ubuntu), to synchronize two different sources ?
Results 1 to 1 of 1
AviSynth - Two Audio Sources, One Output Video
By lomaidala in forum EditingReplies: 0Last Post: 15th Nov 2021, 17:10 -
Trying to sync video and audio from 2 completely different sources...
By ThaKarra in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2021, 03:59 -
Video and Audio Synchronization
By Anotia in forum Newbie / General discussionsReplies: 6Last Post: 17th Aug 2019, 15:21 -
Syncing Audio From Different Video Sources With Different FPS
By StaticSense in forum AudioReplies: 18Last Post: 6th Nov 2018, 10:26 -
any easy and simple software to fix video and audio out of synchronization?
By kenny1999 in forum Newbie / General discussionsReplies: 9Last Post: 4th Oct 2018, 09:18
