Okay, thankyou, i never had these problems before, because i capture/record with ProRes422LT.
Is there any good "inspection" program to read out video file properties, for MAC i prefer, or Windows, i notice also i can't load a .avi file into Davinci Resolve..
I guess i'll stick to ProRes422LT seeing all this.
When i convert (625i50) analog to SDI my Video Assist monitor/recorder still states the resolution as 625i50 at the SDI input
Sorry OP, for being off subject, working with avi files is out of my league
btw.. my guess is that this is also a VHS copy-recording from another tape format, the orginal recording was made on a camcorder,
The original camcorder tapes are not available anymore ?
Results 31 to 38 of 38
If that was a question, the answer is: your eyes. There is nothing better than your own judgement to understand the "architecture" of a video. Open it and check field by field, frame by frame, telecine/interlacing structure, analyze levels, colors, parameters (DAR, SAR, PAR), etc.Is there any good "inspection" program to read out video file properties, for MAC i prefer, or Windows,
master poisondeathray wrote some posts in the recent weeks about that, search the forum.i notice also i can't load a .avi file into Davinci Resolve
I do not understand what you want to say, sorryWhen i convert (625i50) analog to SDI my Video Assist monitor/recorder still states the resolution as 625i50 at the SDI input -
Well in my opinion, if you want to do it right, you don't use DAR at all, ever. Crop then apply SAR(*) of analog NTSC video which is 10:11. This btw. also means the DAR of an uncropped 720x480 video is not 4:3, it is 15:11.
(*) Edit: Sample Aspect Ratio, same as PARLast edited by Skiller; 29th Aug 2023 at 12:56.
Yes, he can also crop and specify PAR (your SAR definition is different than mine, I used SAR as Storage Aspect Ratio). But I doubt Eric can manage that, even because he uses a GUI.
Ah yes, there may be confusion because both are abbreviated the same.
What I mean by SAR is "Sample Aspect Ratio", which is essentially the same as PAR "Pixel Aspect Ratio".
Sample Aspect Ratio is technically the right term for analog video, but maybe PAR is the more sane term to use. -
@Skiller, for square pixels, what is the correct NSTC frame? 720x528?Originally Posted by Skiller
Any 15:11 ratio. 720x528 is one. ~654x480 is another. The math is trivial:
if you want a specific height:
or if you want a specific width:Code:new width = desired height * 15 / 11
So if you want a 480 pixel high frame:Code:new height = desired width / 11 * 15
You can't have a fractional or odd width (with 4:2:0 or 4:2:2 subsampling) so truncate to 654.Code:new width = desired height * 15 / 11 new width = 480 * 15 / 11 new width = 654.545454...
... or if you crop the 720x480 NTSC capture to 704x480, the resized (square pixels) frame will become the "familiar" 640x480, or 720x540, or 1440x1080; all exactly 4:3.
Added:
For random cropping you have to do the maths, or simply crop as you like and encode with SAR 10:11 (x264, mp4 container) and let the TV do the rest. Just don't force the TV to play it as 4:3.Last edited by Sharc; 30th Aug 2023 at 02:27. Reason: Added
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 466Last Post: 22nd Aug 2025, 09:30 -
DVD created on Panasonic DMR-ES35V does not show on PC
By Inger in forum Capturing and VCRReplies: 17Last Post: 11th Dec 2021, 02:47 -
Capturing HDMI output from a Panasonic DMR-EZ47V.
By whynotpizza in forum Capturing and VCRReplies: 32Last Post: 8th Jun 2021, 10:09 -
Panasonic DMR-EH52 & Grundig Video2000 2x4 -- weird video distortions
By phelissimo_ in forum Capturing and VCRReplies: 23Last Post: 18th Jan 2021, 19:02 -
Panasonic DMR-ES40V video interface issue
By buck116 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 31st Aug 2018, 13:04
