As the title states I have a clip that suffers from either a poor deinterlace job or something to do with field delay. The video is from the internet best known source Nascars official website. It has been given the black bar 4:3 to 16:9 treatment and is now 1280x720 progessive 29.97fps. Originally this would have been an ntsc 29.97i broadcast I'm assuming in 720x480. Unfortunately instead of leaving it interlaced or properly deinterlacing to 59.94fps they decided to do this. Fast motion is what triggers the artifacts they aren't present in static shots but it being a racing video there's a lot of fast motion. Bill Elliots hand movement shows what I mean. Can this be fixed or not? I've seen people say after bad interlacing is baked in its done and impossible to repair, and I've seen instances where using things like debicubic and qtgmc have been reported to fix it. I'm not sure what makes one fixable and one not so I figured I'd ask for help and maybe learn something as this seems to be the most common issue I see in the types of media I enjoy. Any AviSynth scripts to fix this?
Results 1 to 28 of 28
I don't think you'll be able to get back the smooth motion of 59.94 fps. For 29.97 fps try
Better analysis could be done with a medium speed horizontal panning shot. Especially one with a vertical bar that runs top to bottom.Code:BicubicResize(852,480) QTGMC(InputType=2)
Jag, I tried to find a clip that suited your request I think you can use the light poles as vertical markers and this pace lap is about as medium speed pan as I could find
Here's a start:
Code:LWLibavVideoSource("Horizontal Pan.mp4") AssumeTFF() DeBilinearResizeMT(852,480) BWDIF(field=0) -
Yes, following up with a good motion compensated temporal noise reduction filter will help. I tried
and it looked pretty good. Santiag reduces some of the aliased edges, Since I was using QTGMC to reduce the buzzing edges I added the NR there.Code:Santiag() QTGMC(InputType=2, EZDenoise=2.0, DenoiseMC=true)
As to why I resized to 480 lines -- to deinterlace properly the video needs to be restored to the original height. And you want to use the inverse algorithm that was used to upscale it. DeBilinearResizeMT left fewer artifacts than DeBicubicResizeMT or any of the others. I determined the 480 lines by first guessing that it was upscaled from a standard interlaced NTSC cap. I tried a few other sizes but that appeared to work best. And the width was set to 852 to keep the 16:9 AR.
You can upscale back to the original's 1280x720 if you want. I'd use nnedi3_rpow2, maybe followed by an aWarpSharp2 and Sharpen. -
Thanks for the explanation I appreciate it. I think it looks as good as it can almost all of the interlace artifacts have been taken care of. The only outstanding question I have is if you know of any interpolation that can handle fast motion like racing. I've tried both InterFrame and FrameRateConverter and they both were not able to handle it with any settings I can find. It would be very obvious when the car passed text on the wall or they went under light poles. The car and text or pole would blend together instead of being detected as separate objects. I'd really love to get this back to 59.94 fps as racing footage at 29.97 can get jittery. I'll attach a clip that's been rendered using the previously discussed settings for experimenting if you think you may know of a combination that might work. Thanks again.
RIFE currently gives the best frame rate interpolation for most material. It's still not perfect though.
LWLibavVideoSource("C:\Users\John\Desktop\Interpol ation.mp4", cache=false, prefer_hw=2)
[edit]Code:LWLibavVideoSource("Interpolation.mp4") z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:l=>rgb:709:709:f") Rife(gpu_thread=1, model=9, fps_num=60000, fps_den=1001) z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:709:709:f=>709:709:709:l")
Oops, I forgot to enable scene change detection. See sc and sc_threshold in the RIFE docs.
[/edit]Last edited by jagabo; 28th Aug 2023 at 08:51.
Scene detection works fine in RIFE now? RIFE at default settings works quite well (aside from the glitches it tends to have), but completely ruins scene transitions.
In my experience -- it works better than the previous version of Topaz, but worse than the current one. -
I found rife worked really well for the cars moving against things like the wall or fence but if there was a graphic of the current position of drivers that was static in a corner it didn't handle that. In topaz chronos is useless but Apollo was very close to rife it handled the static graphic very well and only would mess up cars against poles or text on walls every so often. Neither is perfect but Apollo for me in this situation was better.
I thought about doing that the box where driver position is almost always the same square. I could encode two versions one Apollo and one rife and mask the Apollo just over that square. Its an extra step but an option. It seems topaz releases a model then never updates any iterations which is the point of ai, train models to improve, it's frustrating but rife is getting regular updates hopefully rife v5 will release and just work. Overall I'm thrilled with how everything looks from a strict fixing interlace artifacts on progressive video approach it's fixed. I export the 852x480 video into topaz and use the beta nyx compression revert/denoise model to crop to 640x480 then upscale back to 1280x720 and it looks great nyx doesn't distort text or apply blurring/sharpening like the other models it just cleans.
It may be possible to automatically overlay a different interpolation whenever the graphic appears. For example, if the background color is distinctive you could switch on that. Use RIFE() for the main video, Interframe() or FrameRateConverter() for the Graphic. Can you supply s sample with the graphic?
Sure, here you go and this is my current code I'm using so feel free to tweak if you can get a better result. The motion interpolation failing is noticeable by stepping through frames and observing the laps to go counter, it isn't rendering as desired. I'm using model 22 which is supposed to be the latest 4.6 version of RIFE.
Code:LoadPlugin("C:\Users\Documents\AvisynthRepository\AVSPLUS373_x64\plugins\RIFE\RIFE.dll") SetFilterMTMode("QTGMCp", 3) FFmpegSource2("C:\Users\Videos\Static Graphic.mp4", atrack=1) AssumeTFF() DeBilinearResizeMT(852,480) t = QTGMCp( Preset="Placebo", InputType=2, SourceMatch=3, Lossless=2, NoiseProcess=2, GrainRestore=0.4, NoiseRestore=0.15, Sigma=1.8, NoiseDeint="Generate", StabilizeNoise=true ) b = QTGMCp( Preset="Placebo", InputType=3, SourceMatch=3, Lossless=2, NoiseProcess=2, GrainRestore=0.4, NoiseRestore=0.15, Sigma=1.8, NoiseDeint="Generate", StabilizeNoise=true, PrevGlobals="Reuse" ) Repair( t, b, 1 ) BWDIF(field=0) SantiagMod() TurnRight().SantiagMod().TurnLeft() aWarpSharp2() z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:l=>rgb:709:709:f") Rife(gpu_thread=4, model=22, fps_num=60000, fps_den=1001, sc = true, sc_threshold = 1.0) z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:709:709:f=>709:709:709:l") Prefetch(2) -
You can just preserve that area
You still get some distortions in the area around the box but the text in the box remains readable. You may want to apply the sequence only when the "N TO GO" text appears. It may be hard to detect that automatically given how small the text is and how it's devoid of other details that you could use to identify it.Code:cleartext = Crop(178,110,78,16).ConvertFPS(framerate*2) # preserve the N TO GO text (double frame rate with RIFE here) Overlay(last, cleartext, x=178, y=110)#, mask=fmask) # restore the N TO GO text
I threw: Resize(852x480)+Santiag+BasicVSR++(model=6) at it, seems a bit smooth,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I've never heard of basic vsr+ but I definitely need to check it out. Good results better than anything else I've tried on it including topaz. Hopefully videogigagan isn't all hype and videos like this might actually have a chance of being brought into this millennium.
Thanks @Selur
I have a few pages to read.
About 11 gigs of downloads!
Bit big ATM, but I will get back to this down the track.
Just discovered VideoGigaGAN (that seems to be Adobe-backended):
Demo: https://videogigagan.github.io/assets/videos/demo.mp4
Project: https://videogigagan.github.io/
Git: https://github.com/danaigc/videoGigaGanHub -
@forart.it: without the used model, it does not really seem useful.
Bad interlace lines on progressive video
By PanMarSag in forum RestorationReplies: 11Last Post: 22nd Mar 2024, 20:12 -
How to fix this progressive video with bad interlacing artifacts?
By elektro in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2023, 16:52 -
Why NTSC video on PAL TV have interlace artifacts?
By anonymoustly in forum MediaReplies: 11Last Post: 21st Jun 2023, 15:09 -
How to fix this progressive video with terrible interlacing artifacts?
By elektro in forum Newbie / General discussionsReplies: 4Last Post: 30th Apr 2023, 15:27 -
Interlaced Artifacts on Progressive Video?
By TheKCVault in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2021, 17:52
