  1. I have a special type of video that appears to flicker heavily once it's been deinterlaced. I can only assume it happens because of that camera filter or whatever. I don't even know what to call it properly.
    Either way, whenever a video like that is featured (not always, it's a news report), there's bound to be flickering. Is there any way to mitigate it? I used both "Fast" and the default presets, no difference.
    Jan 2016
    The sample you posted is not de-interlaced.
  3. Ah, I was hoping people would download it and deinterlace it on their end. Here's the deinterlaced video, "Fast" preset.
  4. There is a difference in brightness each field (the problem is the source, not QTGMC) - all double rate deinterlacers will show the luminance flicker
    You can try various deflicker scripts/plugins - deflicker, reduceflicker etc...
    This deflicker approach is from Didee
    AVISource("plane.avi").ConvertToYV16(interlaced=true)
    AssumeTFF().QTGMC(preset="faster" , border=true)
    o = last
    sm = o.bicubicresize(360,288) # can be altered, but ~25% of original resolution seems reasonable
    smm = sm.temporalsoften(1,32,255,24,2).merge(sm,0.25)
    smm = smm.temporalsoften(2,12,255,20,2) # most important !
    o2 = o.mt_makediff(mt_makediff(sm,smm,U=3,V=3).bicubicresize(width(o),height(o),0,0),U=3,V=3)
  5. Says "Not a clip" when I try using your script. Maybe it has something to do with "o"? Also, is it applicable to the whole footage, even scenes without flickering?
  6. Originally Posted by Sunk View Post
    Call "o2" , or "return o2"
    No, it's only for flicker , otherwise you risk degrading "normal" scenes
