Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. Here's a version of the script that in-fills only one line of each field, except for the right ~1/4 of the frame where 5 lines are filled after deinterlacing (as before).
    #  Infill a number of lines with data interpolated from the line above
    #  and the line below.  For example, InFilllines(4, 2) will fill lines
    #  4 and 5 with data interpolated from lines 3 and 6.
    function InFillLines(clip v, int ypos, int yheight, float "opacity")
        opacity = default(opacity, 1.0)
        v24 = ConvertToYV24(v)
        top = v24.Crop(0, ypos-1, -0, 1)
        bot = v24.Crop(0, ypos+yheight, -0,1)
        patch = StackVertical(top,bot).BilinearResize(v.width, yheight+2).Crop(0,1,-0,-1).Blur(1.5)
        Overlay(v24, patch, x=0, y=ypos, opacity=opacity)
        ConvertToYV12()
    LWlibavVideoSource("Recording - 0002.mpg")
    AssumeTFF()
    SeparateFields()
    e = SelectEven().InFillLines(282, 1)
    o = SelectOdd().InFillLines(281, 1)
    Interleave(e,o)
    Weave()
    QTGMC(preset="fast")
    right = InFillLines(561,5).Crop(560, 560, -0, 6)
    Overlay(last, right, x=560, y=560)
    You can hardly see that two lines have been infilled on the left 3/4 of the frame.
  2. I can play all of the options on standard VHS tapes. I can't see the quality of the 3D DNR.
    S-VHS ON on frontside, S-Video Out on backside, is the same as
    S-VHS ON on frontside, Normal on backside, is the same as
    S-VHS OFF on frontside, S-Video Out on backside, is the same as
    S-VHS OFF on frontside, Normal on backside
    and also 3D DNR=ON is the same as 3D DNR=OFF
    jagabo:
    1. AmarecTV 3.10 and output to test.avi
    2. AvsPmod 2.7.3.2 -> deinterlacing.avs.
    deinterlacing.avs is the same folder as test.avi video file
    3. Failed on LWlibavVideoSource("test.avi"): Script error: There is no function named 'LWlibavVideoSource'
  3. Any time you get that message it means you need a 3rd party filter. Google for "AviSynth filtername" and you'll usually find the missing filter.
    https://www.google.com/search?q=avisynth+lwlibavvideosource
    In this case it's the LSMASHSource filter:
    http://avisynth.nl/index.php/LSMASHSource
    Download it and put the dll or avsi file(s) in AviSynth's plugins folder(s).
  4. - On the SVHS player on a TV it is just fine on the video (from SCART SVHS to SCART TV), but noisy bottom on converting to computer with different cables.
    - On playing SVHS player on a computer, it is exactly the same on connecting to a) AV1(TV1)/S-Video Out, b) AV1(TV1)/Normal and c) AV2(DECODER/EXT).
    - All the plugins in 64-bits and all the version numbers is the newest, if I understand it correctly.
    - On QTGMC preset, I am using Slower variable, for I had to stress about it again with Very Slow and Ultra Fast.
    - Using deinterface on QTGMC, not deinterlace on QWinFF
    - Input is "Recording - 0003.mpg", output is "out.mp4".
    What is the command you use for AviSynth? Can I use 'ffmpeg -i InFillLines.avs out.mp4' ?
    How can I record the video on AvsPmod?
    It is still disturbing bottom in the video on out.mp4. And there is no sound on out.mp4.
    InFillLines.avs:
    PHP Code:
    function InFillLines(clip vint yposint yheightfloat "opacity")
    opacity = default(opacity1.0)
    v24 ConvertToYV24(v)
    top v24.Crop(0ypos-1, -01)
    bot v24.Crop(0ypos+yheight, -0,1)
    patch StackVertical(top,bot).BilinearResize(v.widthyheight+2).Crop(0,1,-0,-1).Blur(1.5)
    Overlay(v24patchx=0y=yposopacity=opacity)
    ConvertToYV12()
    #running LWlibavVideoSource
    LoadPlugin("C:\Users\johnnie\Documents\video\L-SMASH-Works-r1129.0.1.0\x64\LSMASHSource.dll")
    LWlibavVideoSource("Recording - 0003.mpg")
    AssumeTFF()
    SeparateFields()
    SelectEven().InFillLines(2821)
    SelectOdd().InFillLines(2811)
    Interleave(e,o)
    Weave()
    #running QTGMC
    LoadPlugin("C:\Users\johnnie\Documents\video\masktools2_v2.2.30\x64\masktools2.dll")
    LoadPlugin("C:\Users\johnnie\Documents\video\RgTools-v1.2\x64\RgTools.dll")
    LoadPlugin("C:\Users\johnnie\Documents\video\mvtools-2.7.45-with-depans20210608\x64\mvtools2.dll")
    LoadPlugin("C:\Users\johnnie\Documents\video\NNEDI3_v0_9_4_62\x64\Release_W7\nnedi3.dll")
    Import("C:\Users\johnnie\Documents\video\Zs_RF_Shared.avsi"#V1.161
    Import("C:\Users\johnnie\Documents\video\QTGMC.avsi"#3.384
    QTGMC(preset="Slower")
    right InFillLines(561,5).Crop(560560, -06)
    Overlay(lastrightx=560y=560
