I'm not sure if I want to buy a firewire DVD-RW or a Firewire Hard Drive.
I have a laptop with a 20 gig HDD and I have maxed it out many times with downloads and captures
For about the same price as a DVD-RW i can get a big firewire hard drive.
R they worth it?
Or would it be cheaper to buy an idie drive and a firewire encloser.
Also
Would it be possible to buy an IDIE DVD-RW and a firewire shell?
I would go with the dvd myself but if you need the room, you need the room. If your going to get the harddrive I would suggest the eide drive with the firewire enclosure. It might be a little cheaper and you would have a bigger selection of harddrives to choose from.
why get firewire when you can get U.S.B. 2.0 it tranfer at 480 megabite per sec. It also cheaper than firewire.
Then I'd have to spend anouther $100 for a USB 2.0 card.
My laptop came with a build in firewire bus. -
Well, if you want portability and expandabliity then go with DVD, but if you want alot of storage then go hard drive. I heard alot of people even upgrade the hard drives that come with then, put in another larger or faster because all they are is external IDE adapters that use the firewire interface.
I was thinking of buying a firewire "shell"
That being a device that translates IDE commands into firewire.,
Then I coulg buy a cheap, fast hard drive and a Pioneer AO4 (or 104, whichever is chepaer, I dont' need lots of software and stuff.) -
Yeah, and then you buy one case and you can put many types of devices in there. CDROM,CDRW,DVD,DVDRW,ZIP,and so on.
Before you know it you've got a new pc
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
DVR --> PC Hard Drive (Firewire, USB?)
By CaZeek in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Aug 2008, 17:58
