Hi all, I'm using Subtitle Edit on Windows. I have two .stl subtitle files for the same video - one is exported as EBU STL open subtitling, one is exported as EBU STL teletext with "double height for text" activated.
My client wants me to deliver these two subtitle tracks as one mixed mode .xif file. Whenever I try to merge the two files (Tools > Join subtitles), the teletext properties are lost and I just have a .xif file with all open titles.
I have also tried exporting both as .xif and then merging, but still the closed captioning turns into open subtitling.
Any way to mitigate this with Subtitle Edit or any other software?
Thanks.
Results 1 to 1 of 1
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 12:28 -
Subtitle Edit moves punctuations to the beginning of a line in batch mode
By Nicada in forum SubtitleReplies: 2Last Post: 11th Dec 2021, 16:19 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
Understanding subtitle workshop advanced mode subtitle adjustment
By hibbs in forum SubtitleReplies: 0Last Post: 7th Jan 2019, 22:01 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33
