Here is what I have come up with for 10-bit YUV to RGB, BT.709, range = 0 - 1023.
r = y + 1.53964687446332*(v-512)
g = y - 0.457674666142168*(v-512) - 0.183142873500381*(u-512)
b = y + 1.8141786671051*(u-512)Last edited by chris319; 24th Aug 2023 at 10:16.
Source please and specify if this is 709 or 601.
Thx, whenever i see so many digits after point it's trig my curiosity and raise some question about computing accuracy.
Well it works the best of anything I've tried for BT.709, and I've tried several. There are still some off-by-one errors and one off-by-two error in 10 bit. It is probably what avisynth and ffmpeg should be using for BT.709. It works fine with single-precision floats and does not need double-precision floats. Again, I am using the values in RP-219 as a reference.
Sharc's math is over my head.Last edited by chris319; 25th Aug 2023 at 03:39.
Converting a 10-bit YUV to RGB
By muhahah in forum ProgrammingReplies: 0Last Post: 21st Dec 2021, 05:25 -
FFmpeg problem with rgb to yuv
By Selur in forum Video ConversionReplies: 1Last Post: 17th Jul 2021, 06:56 -
quality while converting RGB-YUV
By taigi in forum EditingReplies: 34Last Post: 23rd May 2021, 23:23 -
Converting Blu-Ray YUV to RGB and back to YUV?
By killerteengohan in forum RestorationReplies: 17Last Post: 17th Mar 2020, 20:42 -
Help Converting YUV to RGB
By chris319 in forum Video ConversionReplies: 7Last Post: 24th Sep 2018, 18:51
