Full disclosure: I have an OLD system, which runs an OLD version of Windows. Because of this, I use an OLD version of MKVToolnix. There may be a newer version that I can use, but for now this is what I have and it's sufficient to demonstrate the problems I'm having. With that out of the way...
This is an old, documented problem: You play an MKV file on (some?) Blu-Ray players, you try to fast forward, and instead it skips to the next file.
When I originally Googled this problem, the stated solution was to just use an earlier version of MKVMerge to re-mux the video. This didn't work. However adding the parameter "--clusters-in-meta-seek", does fix the problem, but only if I use version 5.3.0. If I use anything later, this doesn't work.
Here is the info from an MKV that won't seek on a Blu-Ray player;
Here is the result of using the command;Code:(MKVInfo) |+ Seek head (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo) (MKVInfo) | + Seek position: 4099 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks) (MKVInfo) | + Seek position: 4253 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues) (MKVInfo) | + Seek position: 299689907 (MKVInfo) |+ EbmlVoid (size: 4044) (MKVInfo) |+ Segment information (MKVInfo) | + Timecode scale: 1000000 (MKVInfo) | + Muxing application: libebml v1.3.0 + libmatroska v1.4.0 (MKVInfo) | + Writing application: mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
mkvmerge.exe -o output.mkv --clusters-in-meta-seek input.mkv
with MKVMerge version 5.3.0. This file DOES seek;
And here is the result of the EXACT SAME COMMAND using MKVMerge version 7.0.0, which does NOT seek;Code:(MKVInfo) |+ Seek head (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo) (MKVInfo) | + Seek position: 4099 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks) (MKVInfo) | + Seek position: 4259 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x11 0x4d 0x9b 0x74 (KaxSeekHead) (MKVInfo) | + Seek position: 299638651 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues) (MKVInfo) | + Seek position: 299627552 (MKVInfo) |+ EbmlVoid (size: 4027) (MKVInfo) |+ Segment information (MKVInfo) | + Timecode scale: 1000000 (MKVInfo) | + Muxing application: libebml v1.2.3 + libmatroska v1.3.0 (MKVInfo) | + Writing application: mkvmerge v5.3.0 ('I could have danced') built on Feb 9 2012 10:38:07
As you can see, both of the re-muxed files contain the entry "KaxSeekHead", but the last one also contains "KaxTags".Code:(MKVInfo) |+ Seek head (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo) (MKVInfo) | + Seek position: 4099 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks) (MKVInfo) | + Seek position: 4260 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues) (MKVInfo) | + Seek position: 299689925 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x11 0x4d 0x9b 0x74 (KaxSeekHead) (MKVInfo) | + Seek position: 299702881 (MKVInfo) | + Seek entry (MKVInfo) | + Seek ID: 0x12 0x54 0xc3 0x67 (KaxTags) (MKVInfo) | + Seek position: 299717452 (MKVInfo) |+ EbmlVoid (size: 4010) (MKVInfo) |+ Segment information (MKVInfo) | + Timecode scale: 1000000 (MKVInfo) | + Muxing application: libebml v1.3.0 + libmatroska v1.4.1 (MKVInfo) | + Writing application: mkvmerge v7.0.0 ('Where We Going') 32bit built on Jun 9 2014 15:08:34
It's a pain in the ass to have to keep two different versions of MKVMerge and to manually choose which one gets used.
My question is: What do I have to do on the command line to get MKVMerge 7.0.0 to output a file in the same format as 5.3.0?
Results 1 to 9 of 9
You could download clever FFmpeg-GUI (a very small portable app without installation).
If it runs on your pc, you can remux your mkv with it. -
OK, let me try a different question;
If I were using the very latest version of MKVMerge, what command would I enter into the command line that would mimic the behavior of version 5.3.0 and produce an MKV file that will seek on all Blue-Ray players? Based on my experience so far, I have a strong suspicion that just adding the "--clusters-in-meta-seek" parameters won't be enough. So what other parameters would I need to add? -
I don't have an mkv video to test, or even a BluRay player.
Can you test the following for me?
or maybeCode:mkvmerge.exe -o output.mkv --disable kaxtags input.mkv
Code:mkvmerge.exe --disable kaxtags -o output.mkv input.mkv
or maybeCode:mkvmerge.exe -o output.mkv --disable kaxtags --clusters-in-meta-seek input.mkv
Code:mkvmerge.exe --disable kaxtags -o output.mkv --clusters-in-meta-seek input.mkv
Stuttering with MKV file (SVT-HEVC) on blu ray player Panasonic
By marco000 in forum Video ConversionReplies: 11Last Post: 10th Jul 2021, 09:03 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 13:02 -
Mitsun(Mit-blu 3100) Blu-ray Player not support or playing?
By Shreeux in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Jul 2019, 12:54 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 02:11 -
Sony BDP-S1500 Blu-ray Player , play MKV MPEG2 on USB ?
By s8n in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2018, 22:49
