@rgr that's not a problem really. I never said USE SOME RANDOM JVC assuming it will work. Clearly, a SECAM-capable VCR is a given here! I.e any S-VHS JVC from France will do that or as I said, even if he ends up with a lower-end device that can't transcode as I just said in my message, using an external device to transcode is very easy, if needed. Many capture cards support SECAM directly.
Again, that's a problem he doesn't even have. Cross that bridge when we get there, that is, if we get there.
The entire discussion really boils down to just get a VCR from France/SECAM-Capable multistandard VCR then we can discuss the rest. All those things mentioned in the thread about TV, capture card settings, old live2 vs new live 2, transcoding, etc all come after and can be worked around VERY easily.
Results 31 to 40 of 40
It depends on whether the VCR will play different SECAMs. Western SECAM (France) was different from Eastern SECAM.
@rgr, why do you say this? do you own SECAM tapes and/or French VCRs? If so, trying putting a so-called "Eastern SECAM tape" in it.
or should I skip to the spolier without encouraging you to do the experiment?
There is only one official SECAM tape format used in France and neighboring countries, The MESECAM is basically a bustard PAL format for camcorders and off air recordings, it was never an official tape format. The rest of SECAM variants such as L, B/G, D/K, H, K, M are TV broadcast standards and have nothing to do with VCRs and Camcorders. VCRs labeled as such in the front cassette flap indicate the type of TV tuner on board and has no significance for the cassette format other than 1st word "SECAM".
Why did you share the spoiler... I wanted rgr to try it out
But yes, as dellsam34 said (and this was actually mentioned multiple times across different posts!) there is no such thing as "East SECAM tape" or "West SECAM tape".
On tape, SECAM is SECAM, plain and simple. Broadcast standards are no longer relevant when digitizing tapes.
The reason why EU devices had the ability to read SECAM broadcast was exactly to address that eastern SECAM broadcast, why else do you think mesecam existed? USSR and neighboring market, didn't have any particular JVC variants for that so-called "Soviet SECAM", but mostly "EU" imports, and some MS/AM multi-standards units + of course local models that are just like other regular models.
So to reply back to this
No it does not and this sentence means nothing. If a VCR can play SECAM (which is something any French VCR can do), it can play SECAM. that's it.
Sorry rgr, secam can be tricky :/ -
"In practice, these JVC units correctly record and play back SECAM tapes from PAL+SECAM countries (Eastern Europe/Middle East), but fail on native French SECAM recordings."
"Practical Implications
If the SECAM tape originates from Eastern Europe the HR-S6850 will play it in color (that's MESECAM)
For French-market cassettes do not rely on JVC HR-S6850 as a native SECAM player—for archiving such tapes, use a French SECAM VCR or genuine multisystem unit."
Oh, yesSorry rgr, secam can be tricky :/
I don't know what you're quoting, but a "JVC HR-S6850" can be EU or MS so the french market has 6850(MS).
VHS via DVCAM capture has black and white image on some tapes.Is fine on TV
By Hajker in forum Capturing and VCRReplies: 9Last Post: 6th Oct 2023, 04:35 -
Capture works only in black and white
By xtrips in forum Capturing and VCRReplies: 14Last Post: 25th Nov 2021, 13:03 -
Help in watching VHS-C secam tapes on PAL equp.
By Out_In_The_Cold in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2021, 13:21 -
Hi8 to PC video is black and white
By MPvnX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 4th Feb 2021, 11:51 -
Capturing VHS, Black/White on PC
By Dutchsteammachine in forum Capturing and VCRReplies: 13Last Post: 20th Aug 2020, 11:29
