I have an APEX dvd player, tried to copy a dvd but didn't work, later found out that there was a macrovision thingy going on that won't let me copy. Can anyone help me bypass the macrovision?
Thanks,
Lanimoo
Results 1 to 9 of 9
Go to the DVD hacks section here.
there is information on getting firmware upgrades needed to remove macrovision -
I went to local electrical store (in Australia is Jaycar) and bought a Video enhancer kit worth $40, if works great, enhancers older vhs tapes when recording, the only drawback I found is that it cancells out macrovision from any source you run through it.Bummer
Recorded many DVDs and VHS from the rental shops. Awsome quality.
Cheers
Dave
ps I assume you are talking standalone players here and not pc based onesWelcome my son, welcome to the machine. -
I bought a box (I don't remember the name) at a computer that take my picture from my computer and puts it on tv. Then i put my dvd in my comp and transfered it to my tv and then recorded the dvd with my vcr. Also another product that i found that was usefull but never tried is @ http://www.lik-sang.com/catalog/product_info.php?category=9&products_id=1365&
I went to look for myself, if I get back before I return, Keep me here. -
Yes you are correct, the macrovision thingy is scrambling your copy to VHS. Obvious questions would be; which model APEX drive do you have and have you checked the hacks area of this site for a workaround?
I have an AD-500W, but the stuff in the hack section don't help. It requires me to buy stuff.
I may be wrong, but an RF modulator should bypass macrovision. An example can be found at Radio Shack and will only put you out $30
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F002%5...5Fid=15%2D1244
Problems in copying DVDs that were "dubbed" from VHS
By Quonzer in forum Newbie / General discussionsReplies: 10Last Post: 4th Apr 2011, 07:30 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 22:23 -
dvd recorder/vhs copying question
By nobbydadog in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2007, 07:58
