my terminal is caling error but i fint reason
is say: "no client ID blob available for this device" how i fix this?
please help
Results 1 to 10 of 10
because you need these files for the script to work
So either you don't have an L3 CDM... or you have a problem in the filename
[Attachment 73312 - Click to enlarge] -
generate the files and rename them exactly as device_client_id_blob and device_private_key (remove extension of the file too)
i have look
[Attachment 73316 - Click to enlarge]
i think why is this error show is tihs in headers:
'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.5735.199 Safari/537.36',
there is no android because i dont have android... -
The extension is still there. The top file has the extension .bin
PowerISO picks this up and Windows hides the extension because it only shows the extension for unknown file types.
In your windows explorer, turn on the option to see all file extensions (View - File name extensions)
Then rename both files
device_client_id_blob.bin needs to be device_client_id_blob
device_private_key.pem needs to be device_private_key
Don't worry, I did -
I don't quite understand this "Widevine L3 Decrypter" plugin
I already have it installed on Chrome after clicking and searching for keys:
it shows me
No CDM key pair found!
https://github.com/FoxRefire/wvg/wiki/Getting-started#2-put-cdm-key-pair-files
[Attachment 87563 - Click to enlarge] -
I have already found 28 CDMs in folders, and in the folder there are two files:
1.client_id.bin
2.private_key.pem - should I put these two files in this folder of the "wvg-next" plugin?
[Attachment 87564 - Click to enlarge]
I can't find anywhere the files for the Wvg folder:
"device_client_id_blob and device_private_key"
where to download it?????Last edited by Henryk69; 22nd Jun 2025 at 13:35.
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
Only talk about this device id blob and private key from android phone
By Roward545 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Apr 2023, 16:35 -
how can i fix this 403 Client Error: Forbidden for
By ahmedani in forum Video Streaming DownloadingReplies: 1Last Post: 19th Jul 2022, 04:38 -
yt-dlp error "HTTP Error 403: Forbidden". MPD downloading [ABC.com site]
By nikshell29 in forum Video Streaming DownloadingReplies: 5Last Post: 26th Aug 2021, 15:18 -
How to download this Blob?
By mothernerd in forum Newbie / General discussionsReplies: 1Last Post: 29th Oct 2018, 07:02
