Hello. I'm not a noob but need some help here. So I have downloaded a few Music video DVDs lately. I used AVIDemux to trim and save individual videos and saved them in .mkv container. There is no option to save in .VOB in AVIDemux. However I plan to make DVDs in compliant "VIDEO_TS" format hard copies to play on my Blu-Ray Player. What program do you guys recommend? There should be no re-encoding, just change in container format. I'm on a mac. Thanks! PS I found a few threads on this topic but they are a decade old.
Doesn't the Mac version support "Mpeg-PS Muxer (ff)" for output? Your DVD mastering software might support the resulting MPG files. Or changing the extension from .MPG to .VOB might work (VOB is a slightly modified MPG).
If that doesn't work you can try using ffmpeg (a Mac version is available) to remux from MKV to VOB:
Code:ffmpeg" -i "Video.mkv" -vcodec copy -acodec copy "Video.vob"
Yes there is option to save in Mpeg-PS Muxer (ff). Never knew it existed. It allows to save in ".mpg" format. Thanks, I'll try that in future edits. I've found ShutterEncoder GUI which uses ffmpeg code. Just tried a few conversions, it worked fine .mkv>.VOB 👍
How to convert video_ts folder to mkv without re encoding?
By roberta in forum Newbie / General discussionsReplies: 14Last Post: 14th Aug 2023, 14:21 -
Can a NTSC smart tv play PAL MP4 and vice versa?
By digicube in forum Video ConversionReplies: 3Last Post: 23rd Aug 2022, 15:49 -
VOB to MKV using MakeMkv
By Reddwarf4ever in forum Video ConversionReplies: 2Last Post: 26th Jun 2022, 15:50 -
Re-Encoding Vob File?
By Okiba in forum Video ConversionReplies: 88Last Post: 7th Mar 2021, 07:48 -
Converting MKV to VOB without losing quality
By guy24s in forum Video ConversionReplies: 9Last Post: 11th Apr 2020, 00:24
