The title explains it, NVENCC64 is encoding really slow with only a small GPU Usage,
This is my current .bat script:
"NVEncC64 -i "avisynth.avs" -o "output.mp4" --preset P1 --codec hevc --vbrhq 3500 --audio-codec libmp3lame"
P1 is Performance and higher numbers indicate higher quality
Nvenc, under normal circumstances, uses a built in dedicated chip for most parts of encoding and decoding, with only a small portion of the calculations taking place on the GPU, so low GPU utilization is to be expected.
The only exception is for encode of RGB content, then the entire encode is done on the GPU with no help from the dedicated chip.
Best way to not need 4k proxy files? Faster CPU, faster GPU, or more RAM?
By GoodEnough in forum Newbie / General discussionsReplies: 7Last Post: 6th Feb 2023, 23:34 -
NVENCC64: How to encode only the first audio track?
By RogerTango in forum Video ConversionReplies: 7Last Post: 8th Dec 2022, 21:12 -
Make Potplayer to use GPU instead of CPU
By dusinez in forum Software PlayingReplies: 4Last Post: 14th Jul 2022, 20:13 -
Leawo Video Converter GPU NVIDIA Faster than handbrake GPU NVIDIA.
By artkazuma in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2020, 03:30 -
Does encoding in Handbrake without Audio make the encode faster?
By focuspuller in forum Video ConversionReplies: 10Last Post: 11th Jan 2019, 05:18
