  1. Vidoe:
    https://www.tving.com/player/M000375603
    MPD:
    https://pip-movie-drm-mcdn.tving.com/MOVIE/121/159/C000121159-1/AVC/B0F9A57A/master.ism.json/manifest_1080.mpd?content_type=VOD
    PSSH:
    AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgSEArwQVgXpUWFkyGvFbZEF2IaDHZlcnNlZGlnaXRhbCIQCvBBWBelRYWTIa8VtkQXYkjj3JWbBg==
    LICENSE:
    https://cj.drmkeyserver.com/widevine_license
    I want to decrypt the video protected by drm.
    Does anyone know how to get a key from this mpd?
  2. I want is how to get a key from a drm protected video.
    The video link is here.
    Vidoe:
    MPD:
    PSSH:
    LICENSE:
  3. Step 1. Install tampermonkey
    Step 2. Install eme logger on tampermonkey
    Step 3. Install the stream detector
    Step 4. Go to the desire video and right click on inspect
    Step 5. Go to console and filter init data and you will get a pssh string
    Step 6. Go to keysdb.net and under pssh paste it
    Step 7. Go back to the inspect tool and under network filter on express, if nothing comes, refresh the page while staying on the network tab and you should get, click the first one and copy the http url
    Step 8. Go to keysdb.net tab and under licence url paste the url you just copied
    Step 9. Go back to the network tab and under the license url there is header, copy that and put it in keysdb after Headers: User-Agent: and then press send and if you done everything correctly you will get the kid:key to decrypt the video
    Step 10. Go to the stream detector and refresh the video til you get mpd, right click on it and copy the url..
    Step 11. Now you can use the mpd url and the key from keydb to download and decrypt the file..
    Dec 2021
    england
     --key 0af0415817a545859321af15b6441762:ffd202e054c024ab97946ee5942dd85a
    [Attachment 73292 - Click to enlarge]
