video url: https://www.goclasses.in/s/courses/60fdd8530cf2c7989e1f109d/take
endpoint url: https://www.goclasses.in/s/courses/60fdd8530cf2c7989e1f109d/videos/640cb553e4b0ff5627b9a0d9/get
got spayee stream url: https://d2qny97nu4rj64.cloudfront.net/spees/w/o/60e975430cf20278db21ff30/v/640cb553e4b...0d9/index.m3u8
replaced end with k/timestamp and got timestamp file.
then used the script:
for some reason gives me the error:Code:import binascii from Crypto.Cipher import AES with open("timestamp", "rb") as file: data = file.read() apkid = '6376237653362633665636637343233320' def _decrypt_key(data, apkid): tmp1 = data[0:16] tmp2 = data[32:48] dec1 = AES.new(bytes.fromhex(apkid),AES.MODE_ECB) tmp3 = dec1.decrypt(tmp1) dec2 = AES.new(tmp3,AES.MODE_ECB) return dec2.decrypt(tmp2) result = _decrypt_key(data, apkid) hex_result = binascii.hexlify(result) print(hex_result.decode())
raise ValueError("Incorrect AES key length (%d bytes)" % len(key))
ValueError: Incorrect AES key length (17 bytes)
I haven't tried anything on this, just wanted to hop in and say that you should put code in the CODE tags for easy reading
bro i had done the same thing in the post mentioned for aes 128, got the keys too for that site(futurly.com). This one's giving me trouble for some reason.
Your "apkid" is probably one char to long (the last char looks like a stray space char, 0x20)
Please help me with video downloading
By Marsha0xGriffith in forum Video Streaming DownloadingReplies: 275Last Post: 30th Nov 2025, 10:21 -
Help Downloading video
By gilbertati in forum Video Streaming DownloadingReplies: 4Last Post: 27th Mar 2021, 16:39 -
Can someone help me downloading this video.
By Fool88 in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jan 2021, 07:25 -
Help downloading a video
By mainblue01 in forum Video Streaming DownloadingReplies: 2Last Post: 1st Aug 2019, 17:15 -
downloading subtitles that are not part of video and are overlayed on video
By 3dsmaxed in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2019, 03:41
