  1. I made this for a friend who wanted to download some shows, and noticed that you can get a significant quality boost just by cleaning up the manifest. While not the most exciting streaming service out there, any free site where you can get Dolby audio is worth paying attention to.
    It takes URL as input and supports single episode, range of episodes, full season. and movies. See script documentation for more info.
    You'll find the script here: https://github.com/stabbedbybrick/freevine
    Last edited by stabbedbybrick; 27th Aug 2023 at 13:10. Reason: Added script to github
    Feb 2022
    Search the forum first!
    Great to see more scripts being posted.
  3. Originally Posted by A_n_g_e_l_a View Post
    No point in them lying around collecting dust. Maybe someone out there will find it useful
  4. Hi Brick,
    I've been using python for a little bit for other tools and projects.
    I have got this set up to the point that it's got all necessary components except for the wvd
    After trying to find info on how to create it I'm at a loss even though I can work out some of what the script does, I'm missing a key component. Searching for the path to generating a wvd or finding the blob and such seems a bit more complicated than I can follow. I haven't been able to find info on how to get a blob or such from my firefox cache if that's even possible
    I'm wanting to use this for something that doesn't require a login to view, and it's still stopping.
    Is there any way to have it try without the file or maybe use my firefox cookies or whatever?
    Alternately is there a simple tool to create the wvd from public credentials or my firefox cache?
    Oct 2023
    Afghanistan
    You can get a WVD file in this thread:
    https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
  6. Originally Posted by billybanana View Post
    Thank you!
  7. this is using a deleted/transferred python module "subby" i believe you forked "subby" to use for this
