Hi guys,
I'm trying to download videos from 6play (France) or RTLplay (Belgium), with yt-dlp, without success. I know they are protected by DRM, but with an add-on like VeeVee Downloader, I manage to access the .dash files.
Surely there must be a solution?
Of course, I've already done the update.
The video (only available in Belgium): https://www.rtlplay.be/septante-et-un-p_8533/emission-du-14-08-23-c_13023600
Site requires login.
[Attachment 73260 - Click to enlarge]
[Attachment 73261 - Click to enlarge]
your video is drm encrypted.
your key
Code:b73121625c8398b92092c7c3887b6884:7c0e04ab0085345f6c939c53a650eb26
To download and decrypt your video
your fileCode:N_m3u8DL-RE --key b73121625c8398b92092c7c3887b6884:7c0e04ab0085345f6c939c53a650eb26 "https://lbcdn.6cloud.fr/resource/rtlbe/s/rtl.be/output/f/3/e/f3ed8efd36cba0a1a1ec7503a575fad7a4f77998/static/13023600_a7cd595d9b065c1bed2eff873dd24a4c_web_dash_upTo540p_540p_vbr_cae_drm_software.mpd?expiration=1692404050&scheme=https&groups%5B0%5D=rtlbe&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpYXQiOjE2OTIzNjgwNDksIm5iZiI6MTY5MjM2ODA0OSwiZXhwIjoxNjkyNDA0MDUwLCJyX2hhc2giOiIyZGUxZjdkZGFiZWFjOTE2MTczMzAyYzJjMTA0NGY5ZjNkZjBmNTI2In0.Q_3kJZkYkoslFrEIwz2P-GaYzDMWaDssacnxEJ6OSWc" -M format=mp4
https://www.transfernow.net/dl/202308188TflEiiL
For your learning and your serching on the forum.
you need :
PSSH
Licence Url
Headers with just "x-dt-auth-token"
a valid L3 Cdm.
Same things to decrypt videos on 6play.
Read the sticky threads. -
Thank you very much. I didn't know about the N_m3u8DL-RE tool, I'll take a look at it.
I'm surprised that the quality is so low, I see that in 2023 not everyone is not up to par.
Many thanks again! -
To get the higher quality, you need an L1 CDM, and use some trickery on the MPD to download the 1080 versions.
You'll have to find the 1080p MPD yourself thoughCode:
51032c3aab099e6f66bceabe9c0e9a92:849b1e905c69a0d524e12261a43dcd03 b73121625c8398b92092c7c3887b6884:7c0e04ab0085345f6c939c53a650eb26
Is there some way to see what resolutions need L1 for a video (obviously without downloading and attempting to decrypt) just by looking at a manifest? Rtlplay uses both L3 for lower resolutions and L1 for higher ones.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
For DRMToday you can usually look at the auth-token you need to pass in the headers
For VTMGo and Streamz (also DRMToday) I usually look at:
If that value is HDCP_NONE then it's L3, any other value is L1 in my experience.Code:op.config.HD.WidevineM.requireHDCP
It might be different for other video providers using DRMToday, I'm not 100% sure.
Edit: I just checked for RTLPlay and it has a different JWT layout so that same check does not work.
Top of my head the easiest way to see if something is L1 is this:
Perform key request (usually even when it's L1, you'll still get the L3 keys, right?)
Check the KIDs from the MPD and see if you have the key for the 1080p (or higher) stream.
If it's there: L3, if it's not: L1 (or something else is wrong) -
6Play?
By Hakunamatata67 in forum Video Streaming DownloadingReplies: 69Last Post: 10th Jun 2025, 10:58 -
rtlplay.be
By mohegan in forum Video Streaming DownloadingReplies: 5Last Post: 19th Dec 2023, 12:04 -
Downloading 6play.fr in HD
By dzadzen in forum Video Streaming DownloadingReplies: 0Last Post: 2nd May 2021, 18:07 -
Downloading from 6Play
By Hakunamatata67 in forum Video Streaming DownloadingReplies: 8Last Post: 20th Jul 2019, 02:23
