I was using my Memorex DVD/VCR (6 Head) to playback my old VHS collection of shows I previously recorded (some on that machine, some on older VCRs), and discovered it constantly changes tape speed between SP and SLP. This makes it impossible to watch (lots of static), and hear (audio skips as speed endlessly changes). Store bought ones worked fine. Until I tried some store bought ones I got from my Step-Mom, and some of them did the same, while some of her TV Recorded ones played fine (other store bought played fine). The tapes look fine. I can't tell if my VCR's going, or the tapes are too old (most were form 80's -90's. Maybe one sometime between 2000-2007). I recorded a bit of it and uploaded to Youtube. For some reason, my phone refused to record sound. But you can see the problem I'm having.
https://www.youtube.com/watch?v=PNen81yKBrA
I sadly have no other VCR to use to test if it's my machine or tapes. We threw our old ones out when we moved because we had the combo player. Can anything be done? I tried adjusting tracking but nothing. Is this identifiable as tape vs player?
Possibly your capstan motor driver board is going bad, If so, possible causes can be bad caps, bad hall effect sensor, bad chip. This is not easy to diagnose or repair for an average person. Your best bet is get another VCR, these low budget VCR's are not that expensive, so not worth repairing anyway.
Could this also be caused by lower edge tape damage, and/or the control track head needs cleaning
I tried my VCR cleaner, but nothing. Hoping I could avoid buying a "new" VCR< but oh well.
Open the tape flap and check for edge damage on the tape.
Open the VCR and clean the stationary head near the capstan with Isopropyl alcohol and a Q-tip.
See this image. The bottom arrow points to the control track head and the upper to the linear audio
Do not use Q-tip on the head drum -
Yes! Cleaning the stationary head worked. Tape splay normally again.
Modifying VCR tape motors with variable speed?
By BenKlesc in forum Capturing and VCRReplies: 20Last Post: 24th May 2021, 13:27 -
VCT tape video capture: Tape shows annoying VCR Speed and Tracking bar...
By MoonView in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2021, 21:52 -
Help with VCR playback issue of a family tape.
By kitsu in forum RestorationReplies: 1Last Post: 28th Nov 2020, 13:59 -
Shintom system VCR won't playback properly (eats up tape)
By XGamer23 in forum RestorationReplies: 8Last Post: 8th Sep 2020, 10:38 -
Speed up video to restore original playback speed?
By nekrosoft13 in forum Video ConversionReplies: 6Last Post: 30th Nov 2019, 00:16
