Results 1 to 27 of 27
    Dec 2021
    Scotland
    And the good news is............................... 1080p at last!!!!!!!!!!!!!!!!!!!!!
    Still shitty 96Kbps audio.
    There's a slight difference. Before, the mpd appeared after first advert was completed. Now it doesn't appear until the whole bloody lot have played (effing 5 minutes worth!!).
  2. Nice, thanks for the heads-up. Getting 1080p @ ~6000kbps is not too shabby, even if the audio is still garbage. Might be worth making a script for this site now.
    Dec 2021
    Scotland
    OK, here's mine. Some will say not very sophisticated but vit works and I'm happy with it. Just drop this (I called it ch5.py) into the WKS-KEYS folder. You don't need a header.py file. To run: py ch5.py and follow instructions
    #### version 20230205-1
    import os
    import base64
    import requests
    from pywidevine.L3.cdm import deviceconfig
    from base64 import b64encode
    from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt
    import shutil
    import glob
    ##########useful when used within VS Code to tell it which directory you're in
    abspath = os.path.abspath(__file__)
    dname = os.path.dirname(abspath)
    os.chdir(dname)
    headers = {
        'Accept': '*/*',
        'Accept-Language': 'en-GB,en;q=0.9',
        'Connection': 'keep-alive',
    def cls():
        # posix is os name for Linux or mac
        if(os.name == 'posix'):
            os.system('clear')  # clear is the bash command
        # else screen will be cleared for windows (os name is actually nt for Windows)
        else:
            os.system('cls')  # cls is the batch command
    def WV_Function(pssh, lic_url, cert_b64=None):
        wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic)
        widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=None)
        license_b64 = b64encode(widevine_license.content)
        wvdecrypt.update_license(license_b64)
        Correct, keyswvdecrypt = wvdecrypt.start_process()
        if Correct:
            return keyswvdecrypt
    def generate_pssh(mpd):
        division = mpd.split("cenc:pssh")
        for i in division:
            if i[1:5] == "AAAA":
                break
        pssh = i[1:-2]
        print(f"PSSH is {pssh}")
        return pssh
    def filename():
        output_name = input("What do you want to call your final file? (do not include file .extension like .mp4) ")
        output_name = f"{output_name}.mp4"
        path = f"./Completed/{output_name}"
        # look to see if duplicate filename
        if os.path.isfile(path):
            print(f"\nyou already have a file called {output_name}. Choose another name\n")
            return filename()
        #look to see if any illegal characters in filename
        illegals = "@$%\/:*?\"<>|~`#^+=\{\};!"
        any_illegals = (set(output_name) & set(illegals))
        if not any_illegals:
            return output_name
        else:
            list_illegals = ' '.join(any_illegals)
            print(f"\nyou have included the following which are not legal characters:       {list_illegals}\n")
            return filename()
    cls()
    mpd_url = input("enter mpd URL: ")
    lic_url = input("\nenter licence URL: ")
    mpd = requests.get(mpd_url, headers = headers).text
    pssh = generate_pssh(mpd)
    #get KEY
    keys = WV_Function(pssh, lic_url)
    print("KID:KEY found is " + (keys[0]))
    keys = str(keys[0])
    division = keys.find(":")
    key = (keys[division+1:])
    print(f"   KEY# is {key}")
    print("\n\n")
    os.system(f'yt-dlp --allow-u -f bestvideo -N 6 "{mpd_url}" -o encryptVid.mp4')
    os.system(f'yt-dlp --allow-u -f bestaudio -N 6 "{mpd_url}" -o encryptAud.m4a')
    print("==============================\n\n Decrypting\n\n==============================")
    os.system(f"mp4decrypt --show-progress --key 1:{key} encryptVid.mp4 video_decrypt.mp4")
    os.system(f"mp4decrypt --show-progress --key 1:{key} encryptAud.m4a audio_decrypt.m4a")
    if not os.path.exists("Throwaway"):
        os.makedirs("Throwaway")
    if not os.path.exists("Completed"):
        os.makedirs("Completed")
    cls()
    print("\n\n\n")
    output_name = filename()
    os.system(f"ffmpeg -i video_decrypt.mp4  -i audio_decrypt.m4a -c:v copy -c:a copy mux_file.mp4")
    os.rename("mux_file.mp4", f'{output_name}')
    shutil.move(f'{output_name}', "./Completed")
    for data in glob.glob("*_decrypt*.*"):
        shutil.move(data,"./Throwaway")
    for data in glob.glob("encrypt*.*"):
    shutil.rmtree("./Throwaway")
    print(f"All done.\n\n Your final file '{output_name}' is in 'Completed' folder")
    It seems that some (not many) downloads have two audio options (one for AD). To make sure you get the correct audio stream, it seems that its ID is always 10 (I've now tried quite a few and it always seems to be the case).
    So, change line:
    to
    os.system(f'yt-dlp --allow-u -f 10 -N 6 "{mpd_url}" -o encryptAud.m4a')
  4. im getting this error can u help plz
    \My5_1080p_WEBDL.py", line 6, in <module>
    ModuleNotFoundError: No module named 'pywidevine.L3'
  5. update: got 1 1080p mpd/video but the next episodes download as 720p for some reason its not grabbing the best quality
  6. for some reason its not grabbing and downloading 1080p video/mpd only 720p videos can u help please
  7. Do not send me DM's
    Dec 2021
    Tórshavn
    !. How in blue blazes are you getting the key WITHOUT the kid?
    2. Use Chrome browser to obtain the mpd
    https://akadash0.akamaized.net/hydra/C5164552461/C5164552461A/20230809180211/C5164552461-tt.mpd?CMCD=ot%3Dm%2Csid%3D%22087903c8-3623-486b-8335-5733439c24f3%22
    3. MY5 uses two KID's but both supply the same key from the license server.
    KID:KEY -> fb03e420fbca46a28c0e80af28f2369b:3839f55e8424c1f52 3919370f9a10567
    KID:KEY -> e579bcbb19d2b5d881004a8088aeb84f:3839f55e8424c1f52 3919370f9a10567
    You should be able to do this in your sleep, you've told us all many times just how brilliant you are.
  8. i have got both key and kid now cant get the 1080p mpds
  9. Do not send me DM's
    Dec 2021
    Tórshavn
    here's a little tip, try it on a newer programme. Something that was added to the catch up service AFTER they changed the stream resolution.
    Try it with say, todays Home and Away
    https://www.channel5.com/home-and-away/season-2022/a1e7a3e3-6030-4fd5-a134-aec1f481aed4
    Or pay attention to the mpd.
    https://akadash0.akamaized.net/hydra/C5164552463/C5164552463A/20230811205053/C5164552463_720p-tt.mpd?CMCD=ot%3Dm%2Csid%3D%2296544783-abb6-47b7-b2ee-6a6c7925253d%22
    remove _720p
  10. Originally Posted by Sorenb View Post
    https://www.channel5.com/show/wonders-of-the-moon-with-dara-o-briain/season-1/episode-1
    720p mpd https://akadash0.akamaized.net/hydra/C5455940001/C5455940001B/20230816113129/C54559400...6ce870f84d6%22
  11. Do not send me DM's
    Dec 2021
    Tórshavn
    Originally Posted by Dannyboi View Post
    i have got both key and kid now cant get the 1080p mpds for some reason im only getting 720p mpds and videos not 1080p
    see 720p mpd: https://akadash0.akamaized.net/hydra/C5311390001/C5311390001B/20230123180628/C53113900...00c7f813202%22
    tv show: https://www.channel5.com/show/we-love-dad-s-army
    Dads army 1080p mpd
    https://akadash0.akamaized.net/hydra/C5311390001/C5311390001B/20230123180628/C5311390001_720p-tt.mpd?CMCD=ot%3Dm%2Csid%3D%223c7c5067-d0f7-443b-a74b-f00c7f813202%22[
  12. Originally Posted by Sorenb View Post
    remove _720p
    yea that worked thanks
  13. Originally Posted by Sorenb View Post
    remove _720p
    yea that worked
    Dec 2021
    Scotland
    Modified script to include when 720p is included in the mpd url:
    #### version 20230816-1  remove 720p from URL (if required) to give 1080p
    import os
    import base64
    import requests
    import shutil
    import glob
    os.chdir(dname)
    headers = {
        'Accept': '*/*',
    def cls():
        else:
        if Correct:
        for i in division:
                break
        pssh = i[1:-2]
        return pssh
    def filename():
            return filename()
            return output_name
        else:
            return filename()
    cls()
    if '_720p' in mpd_url:
        mpd_url = mpd_url.replace('_720p', '')
    #get KEY
    keys = str(keys[0])
    print("\n\n")
    cls()
    print("\n\n\n")
  15. Originally Posted by deccavox View Post
    import os
    import base64
    import requests
    import shutil
    import glob
    os.chdir(dname)
    headers = {
        'Accept': '*/*',
    def cls():
        else:
        if Correct:
        for i in division:
                break
        pssh = i[1:-2]
        return pssh
    def filename():
            return filename()
            return output_name
        else:
            return filename()
    cls()
    #get KEY
    keys = str(keys[0])
    print("\n\n")
    cls()
    print("\n\n\n")
    so we just add the mpd, the tool removes the 720p and downloads 720p yea, shame we cant just add the url instead of mpd
    is there a script like this to download from uktv in 1080p?
  16. Do not send me DM's
    Dec 2021
    Tórshavn
    There is.
    I've written quite a few. None in python, though.
    Dec 2021
    Scotland
    UKTV. Actually very similar to My5:
    import os
    import base64
    import requests
    import shutil
    import glob
    os.chdir(dname)
    headers = {
        'Accept': '*/*',
    def cls():
        else:
        if Correct:
        for i in division:
                break
        pssh = i[1:-2]
        return pssh
    def filename():
            return filename()
            return output_name
        else:
            return filename()
    cls()
    #get KEY
    keys = str(keys[0])
    print("\n\n")
    cls()
    print("\n\n\n")
  18. Sorry to be a bother chaps,.... but does this uptodate script for my5 which auto selects 1080p still work,.... because i'm sure it was working last week, but after pasting the mpd into the elevated cmd prompt, it asks for the lic url,... so far so good,.... network tab, lic,... shows two calls... oddly neither work, but come up with errors. but only after showing some of the subtitles.
    https://www.channel5.com/show/holidaying-with-jane-mcdonald/season-1-5b86f94c-cf0a-4ff...6844/episode-3
    mpd https://akadash0.akamaized.net/hydra/C5466270003/C5466270003B/20230906122503/C54662700...%2Cst%3Dv%2Csu
    lic call 1 (using copy link address)
    https://cassie.channel5.com/api/v2/licences/widevine/491/C5466270003?expiry=1694551689...a5%22%2Cst%3Dv
    lic call 2
    both lic calls seem identical but under preview tab both are different. using latest version of chrome win 10 64bit.
    (I just want to know where I'm going wrong please).
    I decided to give firefox a go.... and it did start to work... right up until i got this error....
    audio_decrypt.m4a: No such file or directory
    File "D:\YT_Rips\WKS-KEYS\CH5.py", line 113, in <module>
    FileNotFoundError: [WinError 2] The system cannot find the file specified: 'mux_file.mp4' -> 'jms01e03.mp4'
    okay.... it's downloading vid, and decrypting,... but no audio???
    Still trying to suss out what is going on.... the script as it looks when downloading
    [generic] Extracting URL: https://akadash0.akamaized.net/hydra/C5466270003/C5466270003B/20230906122503/C54662700...fa80fb3c096%22
    [generic] C5466270003_SD-tt: Downloading webpage
    WARNING: [generic] Falling back on generic information extractor
    [generic] C5466270003_SD-tt: Extracting information
    [info] C5466270003_SD-tt: Downloading 1 format(s): 1
    [download] encryptVid.mp4 has already been downloaded
    [download] 100% of 877.02MiB
    WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging.
    If you experience any issues while using this option, DO NOT open a bug report
    ERROR: [generic] C5466270003_SD-tt: Requested format is not available. Use --list-formats for a list of available formats
    Decrypting
    I don't know if i am right or not,... but during the download is the audio called SD-tt ??
    I do not know if this will help but my version of yt-dlp is 2023.7.6.0 13.3mb
    Dec 2021
    england
    just remove _SD-tt you will be fine download video and audio
    https://akadash0.akamaized.net/hydra/C5466270003/C5466270003B/20230906122503/C5466270003.mpd?CMCD=ot%3Dm%2Csid%3D%22e103d00b-4f64-42b6-946f-36cef2ec9932%22
  20. Thank you for the reply iamghost,....
    That's insane..... just that part even stopped the 1080p stream,.... I was only getting 720p and no audio...
    Really appreciate your input and help. Thanks again.
    Dec 2021
    Scotland
    So far, I've found 3 variations within the mpd url ('_720p', '_SD' and '_SD-fixed-label'). There may be more. They all seem to have a common theme, so hopefully, this will deal with the lot:
    #### version 20230816-1  remove 720p from mpd_url (if required) to give 1080p
    #### version 20230908-1  remove '_SD-fixed-label' from mpd_url
    #### version 20230908-2  deal with '_SD-tt' in mpd_url
    #### version 20230910-1  deal with all variations in mpd_url between '_' and '-tt'
    import os
    import base64
    import requests
    import shutil
    import glob
    os.chdir(dname)
    headers = {
        'Accept': '*/*',
    def cls():
        else:
        if Correct:
        for i in division:
                break
        pssh = i[1:-2]
        return pssh
    def filename():
            return filename()
            return output_name
        else:
            return filename()
    cls()
    mpd_url = mpd_url[:mpd_url.find('_')] + mpd_url[mpd_url.find('-tt'):]
    #get KEY
    keys = str(keys[0])
    print("\n\n")
    cls()
    print("\n\n\n")
  22. Member
    Nov 2022
    Europe
    Does anyone know how to access the API on channel5? I want to automate a script but they have some weird protection. Normally you would make a request with the correct headers and then parse the response data. But the response on channel5 is encrypted with what looks like AES? There's an IV and a data string but I can't find the key anywhere. First I thought the auth in the episode json would be the key, but apparantely not. And where the hell is that auth coming from anyway? It's all very annoying and I would love some pointers.
  23. Originally Posted by scryclwn View Post
    They use AES & HMAC ... and it changes regularly (it's changed at least twice since they added 1080p I believe)
  24. Member
    Nov 2022
    Europe
    Oh damn, that sounds like it's above my skill level. You don't happen to have any tips on how to handle it?
  25. Originally Posted by scryclwn View Post
    Unfortunately not
  26. Member
    Nov 2022
    Europe
    Unfortunately not
    That's okay, thanks anyway. You gave me some new information I can use in my searches, I appreciate that
  27. This is my batch file for My5 downloading:
    Channel 5.bat
    @ echo off
    echo Requirements; yt-dlp.exe , mp4decrypt.exe, aria2c .exe, ffmpeg.exe, CDRM-Project website.
    echo.
    echo Extentions for web browser; TamperMonkey, EME logger for TamperMonkey, MPD detector
    echo.
    set path=C:\Widevine
    set /p folder= Video Name to be Saved as (No spaces) :
    echo.
    mkdir C:\Widevine\Downloads\%folder%
    set /p stream=Input MPD URL :
    yt-dlp --external-downloader aria2c --allow-unplayable-formats -F "%stream%" -v
    echo.
    set /p video=Video Quality ID :
    echo.
    set /p audio=Audio Quality ID :
    echo.
    yt-dlp.exe --external-downloader aria2c --allow-unplayable-formats --verbose -f %video%+%audio% "%stream%" -o "C:\Widevine\Downloads\%folder%\encrypted.%%(ext)s "
    ren "C:\Widevine\Downloads\%folder%\*.mp4" encrypted.mp4
    ren "C:\Widevine\Downloads\%folder%\*.m4a" encrypted.m4a
    echo.
    set /p idkey1=Input 1st id:key from PSSH:
    echo.
    set /p idkey2=Input 2nd id:key from PSSH:
    echo.
    echo Decrypting and Merging .........
    mp4decrypt.exe --key %idkey1% --key %idkey2% C:\Widevine\Downloads\%folder%\encrypted.mp4 C:\Widevine\Downloads\%folder%\decrypted.mp4
    mp4decrypt.exe --key %idkey1% --key %idkey2% C:\Widevine\Downloads\%folder%\encrypted.m4a C:\Widevine\Downloads\%folder%\decrypted.m4a
    ffmpeg -hide_banner -i C:\Widevine\Downloads\%folder%\decrypted.mp4 -i C:\Widevine\Downloads\%folder%\decrypted.m4a -acodec copy -vcodec copy C:\Widevine\Downloads\%folder%.mp4
    RMDIR /s /q C:\Widevine\Downloads\%folder%
    ffplay C:\Widevine\Downloads\%folder%.mp4
    pause
    echo Completed .........
    cls
    Works for me!
