Good Aternoon.
I am trying to to take a MKV file and keep the only the atmos audio track. I read on different post about EAC3to program. I tried it and I recieved an error message. Can somone please assist me?
Thank you
ac3to (v3.36) is up to date
Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed
http://www.nero.com/eng/store-blu-ray.html
CAUTION: You need Nero 7. Nero 8 won't work with eac3to.
ArcSoft DTS Decoder doesn't seem to be installed
http://www.arcsoft.com/products/totalmediatheatre
Sonic Audio Decoder (3.36.0.0) doesn't seem to be installed
Haali Matroska Muxer (2013-04-14) is installed
There's a new version (2013-06-23) available
http://haali.net/mkv
Nero AAC Encoder (1.5.4.0) is installed
Surcode DTS Encoder doesn't seem to be installed
http://www.surcode.com
Results 1 to 19 of 19
Yeah, I wrote one of those eac3to posts in your thread about conversion mkv to UHDBD. Where you can convert TrueHD only into TrueHD+AC3.
Eventhough this thread title would suggest the opposite, you say you want to create a mkv. Probably from a m2ts. Then johns0 is right. Use MKVToolnix if you wish for a GUI to mkvmerge. Just drop the m2ts in the source window. Embedded AC3 tracks will show as separate tracks which you can choose to keep or ditch. No audio has to be encoded/decoded, just demuxing and de-interleaving, and muxing to matroska.
Or is your title correct? That would read as if you want to do it the other way around. -
Hey thanks for the reply guys..
I have an MKV file. I want to do the oppsite. Turnto a M2TS. Do i do the same procedure. -
Yes it does. And for a standalone m2ts there's no need to embed an AC3 track
Good Afternoon.
Sorry for the late reply.
I am trying to to convert a MkV to an M2TS for on BD.
I just tried using a MKV file. It works perfeclty ,video and sound. It has an HEVC video track. It also has 5 different audio tracks. I am only intrested keeping the HEVC Video and an TRHD 8 channels audio track. I tried Clever ffmeg, Tsmuxer , BD rebuilder. When i get to the M2TS file, some reason it does not play right. It s like garbled or jumpy. It looks like something to do with the TRHD track. Any suguesstions, if poosible?
Thank you -
https://www.videohelp.com/software/Clown-BD
You may need to process the output again after using this but it'll convert an MKV with TrueHD audio into a bluray folder/M2TS file. -
Hi I recieved this error message
Bitstream parsing for tracks 1 and 2 failed. <WARNING>
Demuxing these tracks may still produce correct results - or not. <WARNING>
This video conversion is not supported. <ERROR> -
clever FFmpeg-GUI can mux hevc+trhd8 from mkv to m2ts and vice versa.
Edit: Tested with Atmos 7.1 today, works fine.Last edited by ProWo; 23rd Aug 2023 at 05:01. Reason: retested with atmos sample
Here is my MediaInfo. I am going to try to demux the mkv file now wirth tsmuxter.
Complete name : G:\Bullet.Train.mkv
Format : Matroska
Format version : Version 4
File size : 77.2 GiB
Duration : 2 h 6 min
Overall bit rate : 87.4 Mb/s
Frame rate : 23.976 FPS
Movie name : Bullet.Train
Writing application : mkvmerge v71.1.0 ('Fortitude') 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 68.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.346
Stream size : 60.9 GiB (79%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1038 cd/m2
Maximum Frame-Average Light Level : 395 cd/m2
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 843 kb/s
Maximum bit rate : 6 990 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.40 GiB (4%)
Title : TrueHD 7.1 Atmos
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 3 765 kb/s
Channel layout : C L R LFE Lb Rb Lss Rss
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Stream size : 3.33 GiB (4%)
Title : DTS-HD MA 7.1
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 579 MiB (1%)
Title : DD 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #4
ID in the original source medium : 4353 (0x1101)
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Title : DD 5.1
Language : English
Default : No
Forced : No
Audio #5
ID in the original source medium : 4354 (0x1102)
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 2 257 kb/s
Channel layout : C L R Ls Rs LFE
Bit depth : 16 bits
Stream size : 1.99 GiB (3%)
Title : DTS-HD MA 5.1
Language : French
Default : No
Forced : No
Audio #6
ID in the original source medium : 4355 (0x1103)
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 2 243 kb/s
Bit depth : 16 bits
Stream size : 1.98 GiB (3%)
Language : Portuguese
Default : No
Forced : No
Audio #7
ID in the original source medium : 4356 (0x1104)
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 2 246 kb/s
Bit depth : 16 bits
Language : Spanish
Default : No
Forced : No
Audio #8
ID in the original source medium : 4357 (0x1105)
Format : DTS XLL
Codec ID : A_DTS
Bit depth : 16 bits
Language : Thai
Default : No
Forced : No
Audio #9
ID in the original source medium : 4358 (0x1106)
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Stream size : 174 MiB (0%)
Title : DD 2.0
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 54 min
Bit rate : 2 b/s
Frame rate : 0.011 FPS
Count of elements : 76
Stream size : 1.79 KiB (0%)
Title : FORCED
Language : English
Default : No
Forced : Yes
Text #2
Format : UTF-8
Duration : 2 h 0 min
Bit rate : 61 b/s
Frame rate : 0.225 FPS
Count of elements : 1626
Stream size : 54.0 KiB (0%)
Language : English
Default : Yes
Forced : No
Text #3
Format : UTF-8
Duration : 2 h 2 min
Bit rate : 65 b/s
Frame rate : 0.242 FPS
Count of elements : 1782
Stream size : 59.1 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #4
ID in the original source medium : 4768 (0x12A0)
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 41.1 kb/s
Frame rate : 0.508 FPS
Count of elements : 3734
Stream size : 36.1 MiB (0%)
Language : English
Default : No
Forced : No
Text #5
ID in the original source medium : 4769 (0x12A1)
Format : PGS
Muxing mode : zlib
Duration : 1 h 58 min
Bit rate : 36.7 kb/s
Frame rate : 0.446 FPS
Count of elements : 3174
Stream size : 31.1 MiB (0%)
Language : English
Default : No
Forced : No
Text #6
Format : PGS
Muxing mode : zlib
Bit rate : 1 359 b/s
Frame rate : 0.022 FPS
Count of elements : 154
Stream size : 1.11 MiB (0%)
Language : English
Default : No
Forced : No
Text #7
ID in the original source medium : 4770 (0x12A2)
Format : PGS
Muxing mode : zlib
Duration : 2 h 5 min
Bit rate : 27.4 kb/s
Frame rate : 0.425 FPS
Count of elements : 3186
Stream size : 24.5 MiB (0%)
Language : Chinese
Default : No
Forced : No
Text #8
ID in the original source medium : 4771 (0x12A3)
Format : PGS
Muxing mode : zlib
Bit rate : 25.7 kb/s
Frame rate : 0.432 FPS
Count of elements : 3242
Stream size : 23.0 MiB (0%)
Language : Chinese
Default : No
Forced : No
Text #9
ID in the original source medium : 4772 (0x12A4)
Format : PGS
Muxing mode : zlib
Bit rate : 28.0 kb/s
Frame rate : 0.399 FPS
Count of elements : 2990
Stream size : 25.0 MiB (0%)
Language : French
Default : No
Forced : No
Text #10
ID in the original source medium : 4773 (0x12A5)
Format : PGS
Muxing mode : zlib
Duration : 2 h 4 min
Bit rate : 24.4 kb/s
Frame rate : 0.424 FPS
Count of elements : 3182
Stream size : 21.8 MiB (0%)
Language : Korean
Default : No
Forced : No
Text #11
ID in the original source medium : 4774 (0x12A6)
Format : PGS
Muxing mode : zlib
Bit rate : 33.8 kb/s
Frame rate : 0.428 FPS
Count of elements : 3210
Stream size : 30.2 MiB (0%)
Default : No
Forced : No
Text #12
Format : PGS
Muxing mode : zlib
Bit rate : 1 837 b/s
Frame rate : 0.029 FPS
Count of elements : 216
Stream size : 1.64 MiB (0%)
Title : FORCED
Default : No
Forced : No
Text #13
ID in the original source medium : 4775 (0x12A7)
Format : PGS
Muxing mode : zlib
Bit rate : 30.2 kb/s
Frame rate : 0.429 FPS
Count of elements : 3216
Stream size : 27.0 MiB (0%)
Language : Spanish
Default : No
Forced : No
Text #14
Format : PGS
Muxing mode : zlib
Bit rate : 1 537 b/s
Frame rate : 0.025 FPS
Count of elements : 190
Stream size : 1.38 MiB (0%)
Title : FORCED
Language : Spanish
Default : No
Forced : No
Text #15
ID in the original source medium : 4776 (0x12A8)
Format : PGS
Muxing mode : zlib
Bit rate : 27.9 kb/s
Frame rate : 0.438 FPS
Count of elements : 3284
Stream size : 24.9 MiB (0%)
Language : Thai
Default : No
Forced : No
Text #16
Format : PGS
Muxing mode : zlib
Bit rate : 1 580 b/s
Frame rate : 0.030 FPS
Count of elements : 224
Stream size : 1.41 MiB (0%)
Title : FORCED
Language : Thai
Default : No
Forced : No
Text #17
ID in the original source medium : 4777 (0x12A9)
Format : PGS
Muxing mode : zlib
Bit rate : 1 571 b/s
Frame rate : 0.024 FPS
Count of elements : 182
Title : FORCED
Language : French
Default : No
Forced : No
Text #18
Format : PGS
Muxing mode : zlib
Title : FORCED
Language : French
Default : No
Forced : No
Text #19
ID in the original source medium : 4778 (0x12AA)
Format : PGS
Muxing mode : zlib
Bit rate : 73.9 kb/s
Frame rate : 0.660 FPS
Count of elements : 5002
Stream size : 66.8 MiB (0%)
Title : COMMENTARY
Language : English
Default : No
Forced : No
Text #20
ID in the original source medium : 4779 (0x12AB)
Format : PGS
Muxing mode : zlib
Bit rate : 50.7 kb/s
Frame rate : 0.617 FPS
Count of elements : 4680
Stream size : 45.9 MiB (0%)
Title : COMMENTARY
Language : Chinese
Default : No
Forced : No
Text #21
ID in the original source medium : 4780 (0x12AC)
Format : PGS
Muxing mode : zlib
Bit rate : 44.9 kb/s
Frame rate : 0.618 FPS
Count of elements : 4688
Stream size : 40.6 MiB (0%)
Title : COMMENTARY
Language : Korean
Default : No
Forced : No
Text #22
ID in the original source medium : 4781 (0x12AD)
Format : PGS
Muxing mode : zlib
Bit rate : 54.9 kb/s
Frame rate : 0.596 FPS
Count of elements : 4520
Stream size : 49.6 MiB (0%)
Title : COMMENTARY
Default : No
Forced : No
Text #23
ID in the original source medium : 4782 (0x12AE)
Format : PGS
Muxing mode : zlib
Bit rate : 55.1 kb/s
Frame rate : 0.574 FPS
Count of elements : 4354
Stream size : 49.8 MiB (0%)
Title : COMMENTARY
Language : Spanish
Default : No
Forced : No
Text #24
ID in the original source medium : 4783 (0x12AF)
Format : PGS
Muxing mode : zlib
Bit rate : 60.5 kb/s
Stream size : 54.7 MiB (0%)
Title : COMMENTARY
Language : Thai
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:07:30.366 : en:Chapter 02
00:14:58.439 : en:Chapter 03
00:21:59.860 : en:Chapter 04
00:30:31.162 : en:Chapter 05
00:38:59.003 : en:Chapter 06
00:47:24.258 : en:Chapter 07
00:54:30.600 : en:Chapter 08
01:01:24.263 : en:Chapter 09
01:09:27.830 : en:Chapter 10
01:15:58.387 : en:Chapter 11
01:22:23.563 : en:Chapter 12
01:29:35.078 : en:Chapter 13
01:36:52.014 : en:Chapter 14
01:43:45.093 : en:Chapter 15
01:53:58.164 : en:Chapter 16 -
Audio
Codec ID : A_TRUEHD
Bit depth : 24 bits
Stream size : 3.40 GiB (98%)
Language : English
Default : Yes
Forced : No
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Stream size : 60.9 GiB (100%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray -
Your mkv contains Dolby Vision Profile 7 video. This profile is used on UHDBD disc and consists of a baselayer (BL) and an enhancement layer (EL). The latter contains the so-called "RPU", which is Dolby Vision's dynamic metadata.
During mkv creation BL and EL+RPU are interleaved into one videotrack. As such it's called "single track dual-layer". Of which I wouldn't know if tsMuxer will accept on input, and more importantly if it knows how to demux it well. Because DV on UHDBD contains two separate videostreams in one m2ts container. When you check the correct playlist or m2ts from your disc with MediaInfo you'll see Video #1 and Video #2.
If you want to create Dolby Vision m2ts or UHDBD you initially must demux the mkv to its elementary streams. This you can do with gMKVExtractGUI which is a frontend to the MKVToolNix demuxing trool. Realise that the resulting videostream will still contain the two interleaved layers. Which you can further take apart into BL and EL+RPU with quietvoid's dovitool. This is a CLI tool. But for basic needs it's not hard to learn.
Resulting streams BL and EL+RPU can be imported into tsMuxer with your desired audio and mux it to m2ts or UHDBD. If you don't care for Dolby Vision you can choose to import only the baselayer. It's a normal HDR encoded stream as you'll find many on UHDBD without DV.
https://www.videohelp.com/software/gMKVExtractGUI
https://github.com/quietvoid/dovi_toolLast edited by Ennio; 23rd Aug 2023 at 07:06.
MKV to MOV without losing DOLBY ATMOS
By new93 in forum Video ConversionReplies: 6Last Post: 21st May 2023, 21:25 -
How can I remove Dolby Atmos from Dolby Digial E-AC3 5.1?
By wajih94 in forum MacReplies: 3Last Post: 20th May 2021, 03:41 -
Dolby Atmos format
By forsure in forum Blu-ray RippingReplies: 10Last Post: 1st Mar 2021, 18:39 -
Is an audio track in Dolby Atmos or not?
By biosdi in forum AudioReplies: 5Last Post: 23rd Jan 2021, 13:03 -
How can I convert Dolby Atmos to something else?
By Belfaborac in forum AudioReplies: 17Last Post: 2nd Aug 2019, 16:20
