I bet I saw the same question here on VideoHelp a couple of weeks ago, should have bookmarked it. I thought that blocking is unavoidable because of long GOP, so what I do is I backtrack several seconds, and then frame skip forward until the point I am interested in. But then, when played at full speed there is no blocking. So, I guess there is a solution, and I think it was given in the other thread.
So, what do I do to see complete picture, not just assorted squares, in my MPEG-2 video in VDub2?
Thanks!
I actually want to skip every frame one by one without mozaicking. I thought that I can enable some sort of buffer, either in VDub or maybe through AVS script to simplify navigation over videos with very long GOPs.
In VirtualDub2, when you open a video with File -> Open Video File... Use the Files of Type: pulldown to select MPEG Video/systems stream...
Intermittent Audio Playback Issues JVC GR-D250U but FireWire transfer fine
By ArcanaXIX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 27th Oct 2024, 03:32 -
How do you resolve the Virtualdub2 "Requested frame not found" bug?
By Guernsey in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2022, 10:13 -
Distorted capture video input in VirtualDub2, OBS works fine
By NotLikeThis8 in forum Newbie / General discussionsReplies: 12Last Post: 24th Mar 2022, 06:34 -
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 05:25 -
CCD-TR101 Video8 playback no audio, Hi8 playback fine
By erikyater in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Nov 2019, 17:09
