Hello again from Greece.
So...i bought a PCI capture card...
Its ezcap 342B Live Gamer RAW.
I works fine with POT Player...but...since i install the card the pc dont shut down.
I press "Finish" i press the power button...and the pc reboots again.
Cant close it.
They only way to close it is to press the full power button next the electric cable behind the pc.
Try to find a solution in web...nothing...I contact with email to the mechanic of Ezcap, he told me to send him a picture of what my pc is doing...I told him
"its rebooting" !
The drivers of the card are for windows 7...maybe thats the problem, but i dont know what to do...
Any other guy with same problem in the past?
Results 1 to 9 of 9
look up the model of the card and try reading the manual - https://www.ezcap.com/index.php/support/download.html
try to put it in another pci slot if you can
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
The cause is an electrical short when the card is installed, that card is a PCIe not PCI. Does your computer have a PCIe slot? My guess is No, because you indicated that it only has one slot, so i am guessing it's an old computer.
How did you capture Video tapes in the late 80s? I use a 96 PCI Card
By ArtAutDudeJR94B in forum Capturing and VCRReplies: 18Last Post: 12th Mar 2023, 15:41 -
Does anyone have this model of pci card ?
By Caius in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2022, 23:38 -
Pinnacle Studio 8 AV/DV PCI Card and some problems
By Corcoleison in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2020, 13:26 -
Hauppauge Colossus 2 pci capture card
By Muscleman in forum Capturing and VCRReplies: 9Last Post: 25th Feb 2020, 10:09 -
Manual for original Blackmagic Intensity pci-e card
By ereiamjh in forum Capturing and VCRReplies: 14Last Post: 25th Feb 2020, 08:16
