Results 1 to 19 of 19
  1. Hi
    into the cats, but
    if possible I wonder how to catch this condition:
    LSMASHVideoSource("C:\Users\Administrator\Desktop\crop resize\drone 50P movimento veloceDJI_0044.MP4")
    #TurnRight()
    #Turn180()
    #TurnLeft()
    #robocrop()
    ConvertToYUY2(interlaced=false)
    ConverttoYV12(interlaced=false)
    emask = mt_convolution(vertical="-1 2 -1").ColorYUV(off_y=-64).ColorYUV(gain_y=128).mt_expand(chroma="-128").Blur(0.8)
    Overlay(last, Blur(0.6, 0.7), mask=emask)
    assumeFPS(50)
    Prefetch(8)
    the sequence of
    in an .avs script
    via batch commandline
    thanks
  2. you are falling from hacked workflows into hacking windows batch codes, which as it is, windows batch is already a one hack if one wants to really do a work
    in this case we are hacking a problem not to be able to put an line break into a string or variable for a search:
    rem https://stackoverflow.com/questions/54401186/find-a-string-included-carriage-return-in-a-file-windows-batch
    @echo off
    setlocal
    set "script=test_avs.avs"
    set "text1=ConvertToYUY2(interlaced=false)"
    set "text2=ConverttoYV12(interlaced=false)"
    set LF=^
    rem NOTE! the above 2 blank lines are critical - do not remove
    for /f %%a in ('copy /Z "%~dpf0" nul') do set "CR=%%a"
    setlocal enableDelayedExpansion
    findstr /n /r /c:"!text1!!CR!*!LF!!text2!" %script% >nul && echo Found || echo Not found
  3. I understand you cannot change whole lot of your scripts, but you can install python and start to do some utilities in a readable language:
    like calling python script from a batch script and return some value back to batch script, like your example:
    your batch script, which is calling a python utility:
    @echo off
    set "text=ConvertToYUY2(interlaced=false)ConverttoYV12(interlaced=false)"
    start /wait python find_python.py %script% %text%
    if %errorlevel%==0 (echo found it) else (echo did not find it)
    and actual python utility script called find_python.py:
    import sys
    def main(script, text):
        loaded_text = ""
        with open(script, "r") as f:
            for line in f:
                loaded_text += line.strip()
        if text in loaded_text:
            sys.exit(0) #found,   returning 0 to batch script which appears in errorlevel variable
        else:
            sys.exit(1) #not found,  returning 1 to batch script which appears in errorlevel variable
    if __name__ == "__main__":
        usage in cmd:
        python  this_script.py test_avs.avs  ConvertToYUY2(interlaced=false)ConverttoYV12(interlaced=false)
        script = sys.argv[1]
        text = sys.argv[2]
        main(script, text)
  4. Originally Posted by _Al_ View Post
    @echo off
    setlocal
    set LF=^
    mmm thanks but I'm already in a batch procedure: maybe I think I cannot use the setlocal enableDelayedExpansion (or I don't know exactly)
    I have already defined the .avs scripts as
    %cd%\AllSingleRemuxed\%~nx1.avs
    and during execute of the .bat it should be detects if "%cd%\AllSingleRemuxed\%~nx1.avs" contanin the sequence:
    convertToYV12(interlaced=false)
    (case insensitive)
    if this how can I do it?
  5. Code:
    find /I "ConvertToYUY2(interlaced=false)" filename.ext
    /I is for case insensitivity.
    find /h:
    Searches for a text string in a file or files.
    FIND [/V] [/C] [/N] [/I] [/OFF[LINE]] "string" [[drive:][path]filename[ ...]]
      /V         Displays all lines NOT containing the specified string.
      /C         Displays only the count of lines containing the string.
      /N         Displays line numbers with the displayed lines.
      /I         Ignores the case of characters when searching for the string.
      /OFF[LINE] Do not skip files with offline attribute set.
      "string"   Specifies the text string to find.
                 Specifies a file or files to search.
    If a path is not specified, FIND searches the text typed at the prompt
    or piped from another command.
    Note that find does not ignore whitespace and doesn't accept wildcards in the search string. So the above find command line will not find any of these:
    ConvertToYUY2( interlaced=false)
    ConvertToYUY2( interlaced=false )
    ConvertToYUY2(interlaced = false)
    ConvertToYUY2(interlaced=false )
  6. My understanding is that the OP wishes to capture the occurrence of these two lines
    my suggestion is to use this code sequence
    grep -A1 "ConvertToYUY2" | tail -n 1 | grep "ConverttoYV12"
    grep -A1 "ConvertToYUY2" will capture the occurrence of the string ConvertToYUY2 plus the following line
    tail -n 1 will capture the second line while
    grep "ConverttoYV12" will check for the occurrence of the second string.
  7. That what I thought also, that it must search two same lines only one after each other,
    findstr should be a windows equivalent for grep in linux, it allows spaces in string if using /c argument.
    Not sure what to do, how to deal with a particular case if those two lines in Avisynth script have trailing spaces for example. In that case even findstr would not find that string. Maybe there is a way, perhaps another hack.
    how can I do it?
    like I posted, except you need to set script variable with your path
    set "script=%cd%\AllSingleRemuxed\%~nx1.avs"
    also not sure how to not respect case sensitivity, ... , in python no problem, just adding .lower() to each string when comparing it.
  8. Originally Posted by jack_666 View Post
    interesting but in what way I tell to the string that have to act on al specific .avs file?
  9. Code:
    echo Frame_RateScript assume %Frame_RateScript%
            if "%Frame_RateScript%"=="50/1" set ScriptAVS50P=1
            if "%Frame_RateScript%"=="50/1" if exist tempDicituraVFinterlace.txt del tempDicituraVFinterlace.txt
            if "%Frame_RateScript%"=="50/1" echo -vf interlace=lowpass=0:scan=tff>tempDicituraVFinterlace.txt
            if "%Frame_RateScript%"=="50/1" set /p EventualeDicitura_X_FFMPEG_VFinterlaceSe50FPS=<tempDicituraVFinterlace.txt
            if "%Frame_RateScript%"=="50/1" If exist tempDicituraVFinterlace.txt del tempDicituraVFinterlace.txt
            if "%Frame_RateScript%"=="50/1" echo EventualeDicitura_X_FFMPEG_VFinterlaceSe50FPS assume %EventualeDicitura_X_FFMPEG_VFinterlaceSe50FPS%
            if "%Frame_RateScript%"=="25/1" set ScriptAVS25i=1
            if "%Frame_RateScript%"=="25/1" set "EventualeDicitura_X_FFMPEG_VFinterlaceSe50FPS="
            rem *********************************************************************
            if "%dummy%"=="0" echo ### sorgente PARI>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            if NOT "%dummy%"=="0" echo ### sorgente DISPARI>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            if "%Frame_RateScript%"=="50/1" echo ### in questo punto viene rilevato automaticamente il framerate dello script che qui risulta a 50P>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            if "%Frame_RateScript%"=="25/1" echo ### in questo punto viene rilevato automaticamente il framerate dello script che qui risulta a 25>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            if NOT "%dummy%"=="0" if "%Frame_RateScript%"=="50/1" if not "%isMXF%"=="1" echo AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave()>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            if NOT "%dummy%"=="0" if "%Frame_RateScript%"=="50/1" if "%isMXF%"=="1" echo AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave()>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            if "%dummy%"=="0" if "%Frame_RateScript%"=="50/1" if "%isMXF%"=="1" echo AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave()>>"%cd%\AllSingleRemuxed\%~nx1.avs"
            echo Prefetch(8)>>"%cd%\AllSingleRemuxed\%~nx1.avs"
    rem ********************************** rilevamento del doppio inserimento di ConvertToYUY2 e ConvertToYV12 attenzione non cancellare le 2 linne bianche tra LF e rem *****************
    set LF=^
    rem NOTE! le 2 linee bianche sopra sono critiche NON CANCELLARLE
    findstr /n /r /c:"ConvertToYUY2(interlaced=false)!CR!*!LF!ConvertToYV12(interlaced=false)" "%cd%\AllSingleRemuxed\%~nx1.avs" >nul && echo Found || echo Not found
    rem *******************************************************************************************************************************************************************
    pause
    rem *** occorre fare una specie di test dell avs per far si che comprenda se usando framerateconverter va in errore e va sostituito con smoothfps2 ****
    echo scanProgressivo assume %scanProgressivo%
    echo scanInterlace assume %scanInterlace%
    echo fps50 assume %fps50%
    echo RealFPS2 assume %RealFPS2%
    echo pixel_fmt assume %pixel_fmt%
    echo AmbiguoFrameRate assume %AmbiguoFrameRate%
            rem ***** rilevamento del framerate dello script avs ****************
            	for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\core\ffprobe64bit333.exe -hide_banner -loglevel fatal -pretty -select_streams v:0 -show_streams -show_entries stream^=codec_type^,r_frame_rate^,width^,height^,display_aspect_ratio^,duration_ts^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version^,com.android.capture.fps "%cd%\AllSingleRemuxed\%~nx1.avs" 2^>^&1') DO (
                     if "%%~g"=="r_frame_rate" set /a "FinalFrameRate=%%~h"
    oh my limited brain cat but I wonder:
    Now that I have found if an .avs have the 2 occurence is it possible delete the first one?
    so that from
    result is
    [Attachment 73179 - Click to enlarge]
    thanks
  10. grep -A1 "ConvertToYUY2" your_file.txt | head -n 2 | tail -n 1 | grep -c "ConverttoYV12"
    this will output 1 if the sequence is found
    this will output 0 if the sequence is not found
  11. Originally Posted by jack_666 View Post
    I have grep.exe, but head and tail what are? executables?
    OR in alternative: can fart.exe do it? and if yes, in the case of "found": can fart.exe replace the "ConvertToYUY2(interlaced=false)" string with another thing?
  12. you may find this helpful
    https://www.cygwin.com/
  13. It would be difficult to do it in batch script if you want these features: multi-line text or case sensitive or not, perhaps multiple occurrences or trailing spaces in text file.
    I made it using python, following those features, so you can use it or compiled Replace_Lines.exe, it is in that zip file.
    How did I do it:
    made a python script, called replace_lines.py:
    def write_buffer(f, buffer):
        for buffer_line in buffer:
            f.write(f"{buffer_line}\n")
    def replace(filepath:str, search_lines:list, replace_lines:list, case_sensitive=True):
        replaces multiple lines in a text file where lines are loaded as a list with other multiple lines (also passed as a list)
        print("lines_replacement (Case Sensitive!):" if case_sensitive else "lines_replacement (case insensitive):")
        with open(filepath, 'r+') as f:
            lines=[]
            loaded_text=""
            for line in f:
                line = line.strip()
                lines.append(line)
                loaded_text += line
            if case_sensitive:
                occurance_count = loaded_text.count("".join(search_lines))
            else:
                occurance_count = loaded_text.lower().count("".join(search_lines).lower())
            if not occurance_count:
                print(f'  no search pattern found in "{filepath}"')
            else:
                print(f'  found {occurance_count} occurance(s) of search pattern in "{filepath}"')
                f.seek(0)       #move cursor to the beggining
                f.truncate()    #delete everything in file
                lines = iter(lines)
                running = True
                last = None
                search_lines = search_lines if case_sensitive else [i.lower() for i in search_lines]
                while running:
                    if last is not None:
                        buffer = [last]
                    else:
                        try:
                            line = next(lines)
                        except StopIteration:
                            break
                        buffer = [line]
                    for i, search_line in enumerate(search_lines):
                        line_c = line if case_sensitive else line.lower()
                        if not line_c == search_line:
                            if last:
                                last_c = last if case_sensitive else last.lower()
                            else:
                                last_c = None
                            if i and last_c == search_lines[0]:
                                write_buffer(f, buffer[:-1])
                                last = line
                            else:
                                last = None
                            break
                        buffer_c = buffer if case_sensitive else [i.lower() for i in buffer]
                        if buffer_c == search_lines:
                            #pattern found!
                            write_buffer(f, replace_lines)
                            print(f"  replace pattern written")
                            last = None
                            break
                        try:
                            line = next(lines)
                            running = False
                            break
                        last = line
                        buffer.append(line)
        usage:
        python replace_lines.py --file "test_avs.avs" --search "ConvertToYUY2(interlaced=false)\nConverttoYV12(interlaced=false)" --replace "ConverttoYV12(interlaced=false)"
        import argparse
        import os
        parser = argparse.ArgumentParser()
        parser.add_argument("--file", type=str, help="filepath of searched file")
        parser.add_argument("--search", type=str, help="searched lines, separate lines by \\n in a string")
        parser.add_argument("--replace", type=str, help="replace lines, separate lines by \\n in a string")
        parser.add_argument("-cs", "--casesensitive", action="store_true", help="flag will cause comparing strings as case sensitive")
        args = parser.parse_args()
        if not args.file:
            raise ValueError("file argument needed")
        if not os.path.isfile(args.file):
            raise ValueError(f"filepath not found:  {args.file}")
        if not args.search:
            raise ValueError("search argument needed")
        search_lines = args.search.split(r'\n')
        if not args.replace:
            raise ValueError("replace argument needed")
        replace_lines = args.replace.split(r'\n')
        replace(args.file, search_lines, replace_lines, args.casesensitive)
    used pyinstaller.exe (if not installed, could be installed in cmd: pip install pyinstaller), use correct python version in that cmd, use whole paths, even for that py file
    "C:\Users\***user***\AppData\Roaming\Python\Python38\Scripts\pyinstaller.exe"  replace_lines.py --name "Replace_Lines"  -–onefile
    In that replace_lines.py a directory "dist" will be created and Replace_Lines.exe in there.
    Usage for python file or that exe file:
    @echo off
    set "search=ConvertToYUY2(interlaced=false)\nConverttoYV12(interlaced=false)"
    set "replace=ConverttoYV12(interlaced=false)"
    Replace_Lines --file "%script%" --search "%search%" --replace "%replace%"
    rem Replace_Lines --help
    rem python replace_lines.py --file "%script%" --search "%search%" --replace "%replace%"
    rem python replace_lines.py --help
    -when passing search or replace strings, use "\n" to separate lines
    -when searched lines are not found, nothing happens to searched file
    -before you start testing, BACK UP that text file
  14. Image
    [Attachment 73187 - Click to enlarge]
    C:\>replace_lines.exe --file "c:\test_avs.avs" --search "ConvertToYUY2(interlaced=false)\nConverttoYV12(interlaced=false)" --replace "ConverttoYV12(interlaced=false)"
      found 1 occurance(s) of search pattern in "c:\test_avs.avs"
    C:\>
    oh wow but it works!!!
    cheers to the pyton
    very useful thanks !!!!
  15. more safer approach,
    -it rewrites file actually only after there is no possible error while creating new file,
    -also backs up original file , just adding .bak
    import shutil
    from pathlib import Path
    def cs_string(string, case_sensitive):
        if case_sensitive:
            return string
        else:
            return string.lower() if string is not None else None
    def cs_list(lst, case_sensitive):
        if case_sensitive:
            return lst
        else:
            return [i.lower() for i in lst]
        new_lines = []
        with open(filepath, 'r') as f:
            lines=[]
            loaded_text=""
            for line in f:
                line = line.strip()
                lines.append(line)
                loaded_text += line
            if case_sensitive:
            else:
            else:
                lines = iter(lines)
                running = True
                last = None
                search_lines = cs_list(search_lines, case_sensitive)
                while running:
                        buffer = [last]
                    else:
                        try:
                            line = next(lines)
                            break
                        buffer = [line]
                        if not cs_string(line, case_sensitive) == search_line:
                            if i and cs_string(last, case_sensitive) == search_lines[0]:
                                new_lines += buffer[:-1]
                                last = line
                            else:
                                new_lines += buffer
                                last = None
                            break
                        if cs_list(buffer, case_sensitive) == search_lines:
                            #pattern found!
                            new_lines +=  replace_lines
                            print(f"  pattern replaced for writting")
                            last = None
                            break
                        try:
                            line = next(lines)
                            running = False
                            break
                        last = line
                        buffer.append(line)
        if new_lines:
            #backing up file before rewriting it
            path = Path(filepath)
            shutil.copy2(filepath, str(path.parent / f"{path.name}.bak"))
            #rewriting file
            print(f'  Rewriting file. Old file backed up as "{path.name}.bak"')
            with open(filepath, "r+") as f:
                for line in new_lines:
                    f.write(f"{line}\n")
        usage:
        import argparse
        import os
        if not args.file:
        if not args.search:
    both py and exe are in zip:
  16. Ah wow
    it works well:
    %COMSPEC% /c V:\Replace_Lines.exe --file "%cd%\AllSingleRemuxed\%~nx1.avs" --search "ConvertToYUY2(interlaced=false)\nConverttoYV12(interlaced=false)" --replace "ConverttoYV12(interlaced=false)"
    %COMSPEC% /c V:\Replace_Lines.exe --file "%cd%\AllSingleRemuxed\%~nx1.avs" --search "ConvertToYUY2(interlaced=false)\nConvertToYUY2(interlaced=false)" --replace "ConvertToYUY2(interlaced=false)"
    %COMSPEC% /c V:\Replace_Lines.exe --file "%cd%\AllSingleRemuxed\%~nx1.avs" --search "ConvertToYUY2(interlaced=true)\nConvertToYUY2(interlaced=true)" --replace "ConvertToYUY2(interlaced=true)"
  17. Al, for kindness:
    but if I need to search this example:
    LoadPlugin("V:\automazioneclip\AviSynth\MaskTool2\X64\masktools2.dll")
    LWLibavVideoSource("C:\Users\Administrator\Desktop\crop resize\24fps OsmoX3 DJI_0001.MP4")
    #TurnRight()
    #Turn180()
    #TurnLeft()
    #robocrop()
    converttoYV12(interlaced=false).FrameRateConverter(50000,1000, preset = "faster")
    assumeFPS(50)
    the occurance:
    that contains some double quotes " "
    using:
            Replace_Lines.exe --file "%cd%\AllSingleRemuxed\%~nx1.avs" --search "converttoYV12(interlaced=false).FrameRateConverter(50000,1000, preset = "faster")\ConvertToYV12(interlaced=false)" --replace "converttoYV12(interlaced=false).FrameRateConverter(50000,1000, preset = "faster")"
    the program return no search pattern found
    is there a way to search also in string that contain double quote to do a new replacement?
    my target is to find:
    and replace with:
    in this case what could be done?
  18. It looks like when there are quotes in strings, it does not get to python properly, the shell takes them away by arg parser or something, not sure how to deal with it besides escaping those quotes now.
    So when having quotes in search or replace variable, escape them in batch script:
    set "search=ConvertToYUY2(interlaced=false)\nconverttoYV12(interlaced=false).FrameRateConverter(50000,1000, preset = \"faster\")\nConvertToYUY2(interlaced=false)"
    set "replace=converttoYV12(interlaced=false).FrameRateConverter(50000,1000, preset = \"faster\")"
