  1. Hi,
    Is it possible to batch edit the start timings in multiple srt files by the same value using SubtitleEdit?
    canada
    Subtitle edit/tools/batch convert and check offset time codes.
  3. Thanks @johns0, if I had known it was so simple, I wouldn't have asked 😂
  4. Say you have 3 or 4 srt subs? This automatically shifts the times based on 3 or 4 video / audio segments? I don’t have windows and it’s been a couple years since I’ve used SubTitleEdit.
    I realize the original question is say if all of them are off by 2 seconds then it shifts them by 2 seconds in all srts.
