I have a script with approx. 100 lines doing ReplaceFrameRIFE:
Code:function ReplaceFrameRIFE(clip Source, int N, int "X") { # N is number of the 1st frame in Source that needs replacing. # X is total number of frames to replace # e.g. ReplaceFrameRIFE(101, 5) would replace 101,102,103,104,105 , by using 100 and 106 as reference points for interpolation # # requires RGB24, RIFE with model 9 (v4) Trim(Source, N-1, 1)+Trim(Source, N+X, 1) Rife(gpu_thread=1, model=9, factor_num=X+1, factor_den=1, sc=false) # model 9 needed for custom factor/rate AssumeFPS(Source.FrameRateNumerator, Source.FrameRateDenominator) Trim(1,X) #Subtitle("RIFE", align=5) "" # optional label to verify replacement Source.trim(0,N-1) ++ last ++ Source.trim(N+X,0) }
Unfortunately, it generates the error as title in both Vdub and ffmpeg:
I suspect memory allocation issues or some problems with RIFE&GPU.Code:[0 AMD Radeon(TM) Graphics] queueC=1[2] queueG=0[1] queueT=2[1] [0 AMD Radeon(TM) Graphics] bugsbn1=0 bugbilz=0 bugcopc=0 bugihfa=0 [0 AMD Radeon(TM) Graphics] fp16-p/s/a=1/1/1 int8-p/s/a=1/1/1 [0 AMD Radeon(TM) Graphics] subgroup=64 basic=1 vote=1 ballot=1 shuffle=1 vkAllocateMemory failed -2 [avisynth @ 00000181a4c8a3c0] System exception - Access Violation (C:/Program Files (x86)/AviSynth+/plugins64+/ReplaceFrameRIFE.avsi, line 10) <-- indicates a call to RIFE in ReplaceFrameRIFE (avs-rife (after neat).avs, line 57) [in#0 @ 00000181a4c8a280] Error opening input: Unknown error occurred Error opening input file avs-rife (after neat).avs. Error opening input files: Unknown error occurred
Is there any way to force the script to execute itself?
Sometimes the file will load into VDub/ffmpeg and recode goes, but then it crashes early and VDub just closes.
Same when trying to play in MPC.
Edit: latest Adrenaline drivers.
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 22:45 -
{"code": 2048, "message": "Authentication failed"} when getting license
By warmachine in forum Video Streaming DownloadingReplies: 2Last Post: 26th May 2023, 17:34 -
windows 11 crasch "SYSTEM SERVICE EXCEPTION" in win32kbase,sys
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 15th Oct 2021, 03:17 -
Virtualdub export image sequence "Access is denied"
By ecc in forum Video ConversionReplies: 5Last Post: 6th Jul 2020, 09:43 -
DVDLab error: "An attempt was made to access an unnamed file past its end"
By Rain-Maker in forum Authoring (DVD)Replies: 23Last Post: 25th May 2020, 03:59
