Has anyone heard of this device before?
No, I have not heard of that device before. I can't even tell which streaming services or streamed linear TV services it supports based on the information on the website. It might not even be intended for normal consumer use. I can't even tell if it comes with a licensed Android TV OS pre-installed.
Depending on the services you want to watch, you probably would be better off with a Roku Ultra, or a Nvidia Shield TV Pro, or a Google-certified Android TV/Google TV device like the Chromecast with Google TV 4K (if you don't need Ethernet) or something like a Translite Global TL-4KBR (if you do need Ethernet).
[Edit] The webpage for the Amigo 7X (https://www.amino.tv/amino-devices/amigo-7x) describes the device as an "Android TV operator tier certified UHD client TV device" which indicates to me that some IPTV services use it as their set-top box.
For example, I found a page on the Green Mountain Access website that discusses setup for the Amigo 7X to use their service. Green Mountain Access is an Internet/IPTV/Cable TV provider.Last edited by usually_quiet; 7th Aug 2023 at 16:55.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I got mine from my ISP as well. Just wondered if anyone knew anything about it.
So, my suspicion that it is intended to be the equivalent of a cable box for IPTV was correct. I can't say if there are Android apps that cannot be installed on your device. For example, could it be used as a Plex client device?
IPTV is everywhere now. Although I have traditional Xfinity cable TV service, my cable TV box supposedly allows access to a handful of what appear to be cable channels but are provided via IPTV, plus access to select streaming services. Xfinity also has an IPTV subscription option (Flex) for Internet-only subscribers and Xfinity TV service at some colleges is only available via IPTV.Last edited by usually_quiet; 8th Aug 2023 at 08:18. Reason: Fix typo
Capturing in 1080i from set top box
By pthebest19 in forum Capturing and VCRReplies: 8Last Post: 17th Nov 2022, 21:24 -
How to use MPEG 4 set top Box of only playing USB
By shrikant.tillu in forum Latest Video NewsReplies: 3Last Post: 31st May 2021, 01:53 -
TV Receiver ( Set-Top Box ) with Conax card reader, HDMI IN and SCART OUT ?
By Rytis Jonas in forum DVB / IPTVReplies: 1Last Post: 22nd Oct 2020, 21:48 -
DVD Box Set, one flawed disc
By Tom Saurus in forum DVD RippingReplies: 8Last Post: 13th Jul 2020, 18:32 -
VLC cannot read .TS files from set-top box
By pchan in forum DVB / IPTVReplies: 14Last Post: 15th Mar 2020, 10:30
