I wasn't aware of the IO Data website or the fact that there is a different driver for different versions of Windows.
Here's the site (it translates OK with Google Translate):
https://www.iodata.jp/lib/software/g/1780.htm#Windows%2011
Results 1 to 10 of 10
I see V1.15 is available. I installed it (with extreme difficulty due to my poor Japanese; thank goodness for Google Lens). As far as I can tell, one cannot install just the updated driver; you also get "LightCapture" (an MPEG 2 capture program) and a Cyberlink product.
While the driver updated to 1.15, "25fps" or "29.97fps" haven't re-appeared in the list of format presets, but of course can be typed-in.
I therefore suggest that, unless you're having difficulty with your current driver, you do not install the 1.15 driver.Last edited by Alwyn; 23rd Apr 2025 at 05:02.
I stuck to 1.1.0.93.5 2010.06.28 and I have no issues with W11. Framrates 25.0 and 29.97 show up as expected.
Thanks Sharc. Ive amended my last post to be a little more "forceful".
I've installed 1.1.0.93.5, previously newer versions were installed, and it has never reverted back to 25 and 29.97 as standard options.
As well as that, I'm having lots of issues with the audio glitching, however I don't think this is due to any change of drivers. I'm going to perform a refresh of drivers again tonight. If that doesn't work I'm going to purchase another GV-USB2, then compare to see if it really is a hardware issue or not. -
Navigating that website without speaking Japanese is a nightmare and there's a chance that file could be deleted as they move to updated software.
I know this is an old thread, but it's one of the top links on Google, so this seemed like a good place to archive this.
https://files.videohelp.com/u/6586/gvusb2_111.exe
EDIT: Even better, here's just the 32 and 64 bit drivers without all the crap. https://files.videohelp.com/u/6586/Driver.zipLast edited by baker; 7th Feb 2026 at 23:38.
I've updated my website notes on the drivers for the GV-USB2 for anybody who's interested, in particular more info on the 115 driver package.
https://www.aaproductions.net/gvusb2.htm
Hauppauge USB-Live2 vs IO Data GV-USB2
By anachronon in forum Capturing and VCRReplies: 14Last Post: 3rd Nov 2023, 22:09 -
IO Data GV-USB2 + Panasonic ES15 sample
By boolian2 in forum Capturing and VCRReplies: 68Last Post: 6th Jul 2022, 04:20 -
I-o DATA GV-USB2 default settings sample
By boolian2 in forum Capturing and VCRReplies: 31Last Post: 23rd Jun 2022, 21:59 -
AVERMEDIA CE310B or IO DATA GV-USB2, which one and why?
By Joćo Alexandre in forum Capturing and VCRReplies: 1Last Post: 23rd May 2022, 13:29 -
Io Data GV-USB2 V Dub Proc Amp and Histogram
By Alwyn in forum Capturing and VCRReplies: 2Last Post: 6th Oct 2020, 23:37
