Hi everyone,
I received a moldy tape. Non sticky, just light "white powder".
I use an old vcr to clean tapes. I used a 99% isopropyl alcohol to clean the film.
Here's a sample (see attached).
Tape is really damaged or this is because of my attempting cleaning ?
I hope I didn't screw up...
it's highly likely the case, Scrubbing removes magnetic particles from the tape, therefore video information is lost, What you see is the VCR's DOC trying hard to reconstruct missing information from adjacent scan lines, If there is no DOC all those lines will be RF noise like in your avatar. You always start with light cleanup and do a capture pass in a less important VCR, then do a final clean and do another capture in a good VCR. Or use safe detergents instead of Alcohol.
If the mold was mostly on the sides of the tape, opening the shell to remove the tape reels with the tape on them and then dusting off the powdery mold with compressed air might have worked, and stresses the tape much less.
Originally Posted by Dellsham
There is no way to recover it, even a little bit ?
If I use a TapeChek Cleaner 470 RTi, the results will remain the same ? (there's a place in Paris with this tool) -
I'd do another capture of that area and see if the interference/static was in exactly the same spots. That would confirm the tape is damaged.
You should inspect tape - perhaps this is delamination (Sticky-shed syndrome) issue - tape baking may help
Tape deck - head cleaning tape
By hotcheeto in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Sep 2022, 22:00 -
Need mold removal service or someone in Florida that can clean moldy tapes
By Master Tape in forum RestorationReplies: 1Last Post: 13th Jul 2021, 14:24 -
VCT tape video capture: Tape shows annoying VCR Speed and Tracking bar...
By MoonView in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2021, 21:52 -
An inexpensive way of cleaning moldy VHS tapes
By Master Tape in forum RestorationReplies: 17Last Post: 13th Jan 2020, 12:02 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 07:14
