Hi, I'm trying to mux a BD with a DVD.
The problem is the DVD has a kind of NTSC 3:2 pulldown or something,
and I'm not sure if I'm using the correct commands.
script
the sync seems almost correct but sometimes a frame is missing here and there,Code:LoadPlugin("C:\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") LWLibavVideoSource("C:\makemkv\B1_t00_track1_[eng].mkv") Loop(0,0,54) # -2294 QTGMC().SRestore(frate=23.976)
I mean many scene changes are in sync till the end, but some are not.
I think maybe I'm not using the correct command. help please.
dvd sample
https://www.dropbox.com/scl/fo/793e48zokho1tb12tri8y/h?rlkey=go8czfpw79j507sq3fjjxci4h&dl=0
about the audio restoration:
if is possible and simple, I'd like to know how to restore the audio a bit,
as it is so bad, it's like "muffled" / "cottoned" and also has a lot of background rustle/noise.
can I with some avisynth plugin?
or maybe with audacity or others?
audio samples, one is from the DVD, the other, much better, from a 25p WEB-DL,
but I can't use it cause is missing thousands frames.
https://www.dropbox.com/scl/fo/vx24sof4reqfujovufbbe/h?rlkey=4antjnt9hd6nifnr2dgndjui4&dl=0
thanks davexnet, I completely forgot about tfm().tdecimate().
it produces the same result as QTGMC().SRestore(frate=23.976) but is much more faster,
so I could more easily find a doubled frame on the BD, after having removed it, is now all in sync from start to the end.
all is ok, apart the audio that is a pain to listen.
Upscaling after sRestore leads in huge artefacts & sRestore with Vapoursynt
By Platos in forum RestorationReplies: 18Last Post: 27th Apr 2023, 18:03 -
When to TDecimate/SRestore?
By Okiba in forum RestorationReplies: 118Last Post: 18th Aug 2021, 04:55 -
srestore mystery
By semel1 in forum Newbie / General discussionsReplies: 5Last Post: 9th Feb 2021, 10:01 -
SRestore not loading/working with AVISynth
By Fraugster in forum EditingReplies: 11Last Post: 11th Aug 2019, 21:05 -
TDecimate vs. Srestore?
By Vitality in forum DVD RippingReplies: 11Last Post: 19th Jan 2019, 20:13
