Hello,
I've a question regarding Subtitle Edit, my problem is : I got a subtitle from a web-dl and all the content are in CAPITAL Letters, and it's very annoying to watch, so I turned to Subtitle Edit to correct that. Tools/Change Casing bring almost all to normal, with a Capital first letter, BUT the problem here, most of first names and family names are good BUT NOT All, Some mane like ed, family name lake trape, are not Capitalized first letter, I did a spell check, and yes some are found and corrected but not all.
Have you guys already encounter this problem and know how to fix that ? or have a clue ?
kalemvar
The program uses a list of proper names, place names etc. If the names aren't on the list, it won't capitalise.
Does this file looks better to you?
I have used Subtitle Edit Tools > Change casing
Select Normal casing etc
select Fix names casing etc
When you hit OK, you get a list of all sentences that the softare propses to change and you have the option to keep or deselect the lines that are not suitable.
Hope this helps. -
with select normal casing + add names that aren't on the dictionary, subtitle edit has found more incorrect and the sound pretty good now.
quick question, the names I added, are they added to the dictionary of subtitle edit permanently or it's something I have to do for each subtitle ?
Thanks to both of you for your help
It is easy to find out. Just run the file again and see if it shows the extra names that you added. My guess is not.
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 06:44 -
How to hide codes like <br/> />, etc. in subtitle file in subtitle edit?
By Pusat in forum SubtitleReplies: 0Last Post: 10th May 2023, 01:34 -
Formatting the subtitle breaks in Subtitle Edit
By loninappleton in forum SubtitleReplies: 0Last Post: 18th Aug 2022, 15:11 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33
