I have used the latest TMPGEnc encoder and followed the instructions on this site as they had listed out.
It turned out pretty well except for at the end with less than a couple of seconds left to go...the music (audio) cuts off. The file is 8 minutes 32 seconds and the audio drops at 8 minutes 27 seconds abruptly. The actual avi fades out. I also tried converting the avi audio to wav and the same problem.
Any thoughts? Also on a further down note...if I do an autorun function for a cd, if I didn't want to use full screen and use the 352x240 for this VCD...what would I put instead of "fullscreen"? another post suggests "standard" or "half"...if this correct?
[autorun]
open=mplayer2.exe /play/close /fullscreen \yourfile.mpg
thanks in advance!
