Hello!
I have bought a LG RC389H (connected via HDMI) with the intent to digitalize my VHS-C, but there is a problem with all my transfers. They all have som kind of a "buzzing" sound that you can hear when it's relatively quite in the video or white noise. Tried a regular VHS with just white noise and I could barely hear anything even though I cranked up the volume more than enough except for some short static sound from time to time (I had my head right next to the speaker elements, not recommended!)
Troubleshooting that I've done:
- Clean the typical stuffs (Head, rollers, pins etc) with 100% isopropyl
- Unplug nearby electronics
- Turn the plug 180° in the socket
Troubleshooting that I haven't done:
- Clean the tapes
- Clean the audio head
Any idea what the problem is? Or could the last two troubleshootings fix the issue?
Try a filtered power supply.
Do you get it on DVD playback as well? Do you get it when playing commercial VHS tapes (which will have hi-fi audio tracks)? I've had issues high pitched whine and some buzzing with linear/mono audio on these late model LG VCRs but never managed to find what causes it.
Also I know the power supply capacitors can go bad in some of these (I have repaired one), ultimately causing the unit to be stuck on "hello", not sure if that also can cause buzzing problems before it gets that bad.
Strange buzzing sound capturing from Sanyo Betacord VCR
By techmot in forum Capturing and VCRReplies: 6Last Post: 18th Oct 2022, 07:01 -
sony betamax SL-HF100 hifi plays great sound not record sound
By leeuwtje in forum Capturing and VCRReplies: 39Last Post: 16th Jun 2022, 14:11 -
Buzzing audio during capture
By crbd98 in forum Capturing and VCRReplies: 3Last Post: 3rd Apr 2021, 16:59 -
Hiss and buzzing noise reduction on old mono VHS in Audition
By Gwar in forum AudioReplies: 3Last Post: 26th Feb 2021, 15:52 -
Beta hifi vcr playes mono tapes with buzzing sound.
By digicube in forum Capturing and VCRReplies: 3Last Post: 20th Aug 2020, 13:33
