Hi there,
I'm using Subtitle Edit and I want to move test after line break to the next subtitle, does anyone know what kind of hot keys or features can I use?
Preferably in batch. Or is there any other free subtitle tool that I can use?
For example, I want to move 1's "So where's the hot spot? " to the first line of 2's first line.
Split feature is not an option since I have to first create the next time code so the text will be in the right spot.
from
1
00:05:18,708 --> 00:05:22,507
really gonna help me in this game.
2
00:05:22,540 --> 00:05:24,540
to
1
2
Thank you!
I hardly think that thre as a hotkey to do what you want. You have to do it manually.
You might find it easier to do the editting using NotePad or notePad++ just open the srt file with them. -
Also you can make it easier to edit in NotePad if you save it as Test (Whisper Raw).txt insted of Test.srt.
See attached file.
line break not working in karaoke effects (aegisub)
By goorintom in forum SubtitleReplies: 5Last Post: 3rd Sep 2022, 15:11 -
VHS capture with horizontal line move and cut image
By langeloso in forum RestorationReplies: 7Last Post: 22nd Jan 2022, 19:54 -
Divide each line of text into new subtitle line
By martanius in forum SubtitleReplies: 1Last Post: 11th Apr 2021, 16:21 -
Can't hit enter to move to the next line with Aegisub
By shiaws in forum SubtitleReplies: 0Last Post: 20th Apr 2020, 23:25 -
How to add a new line with same text to multiple subtitle at once?
By zyck in forum SubtitleReplies: 7Last Post: 19th Apr 2020, 08:01
