Film needs to be detelecined but credits are interlaced. What's the best way to handle this? If I detelecine the the whole films including credits the credits jump/stutter because of the conversion to 23.976 fps. If I deinterlace at 29.97fps the credit are smooth. I'm stuck. Any help would be greatly appreciated.
I'm sure there will be more elegant solutions but you could just chop the credits off and treat them separately, then rejoin them. Virtual Dub can join files together.
Try clever FFmpeg-GUI.
Load your video, click main, click encode video stream, click keep size, set your encoder, click various, check IVTC, click close various, click encode.
[Attachment 72812 - Click to enlarge]
In the Inverse Telecine process all interlaced frames are deinterlaced automatically. -
If it's simple scrolling credits over a static background IVTC the body of the video to 23.976 fps, then deinterlace the credits to 29.97 (or 59.94) fps and use a frame rate converter to convert the credits to 23.976 fps.
Or, deinterlace the entire video to 59.94 fps. Watched on a 60 Hz display you'll get the usual 3:2 repeat judder of film sources, and the credits will be smooth. -
In the situation "telecined film source OVERLAYED by some real 29.97fps content" there is NO solution to get everything progressive and without judder. No way.
Or does anyone meanwhile know a technique (maybe with some A.I.?) to de-overlay and separate such two layers?
Converting 30fps (prev interlaced) into 60fps interlaced
By Saturn2888 in forum Video ConversionReplies: 4Last Post: 29th Sep 2023, 09:01 -
Interlaced end credits text wobble as it scrolls up
By killerteengohan in forum RestorationReplies: 8Last Post: 13th Feb 2023, 20:15 -
Making credits like in the movies?
By Nixtie in forum Newbie / General discussionsReplies: 0Last Post: 4th May 2020, 15:30 -
How to keep interlaced footage interlaced converting from AVI to MP4?
By kodec in forum Video ConversionReplies: 23Last Post: 1st Jul 2019, 10:36 -
PAL interlaced DVD (Film source) Halo/Mosquito Noise
By camjac251 in forum RestorationReplies: 14Last Post: 5th Feb 2019, 19:29
