Hi,
I'm pretty familiar with the Subtitle Edit's Shortcut Settings editor. However, I haven't been able to define a shortcut that sets the minimum gap to the selected subtitle.
Same situation to assign the minimum duration.
I'm using Subtitle Edit ver. 3.6.13
Suggestions anyone?
Thanks.
I see "apply minimum gap between subtitles" in shortcuts but not the other one.
But "minimum duration" in general settings and "fix short display times" in fix common errors -
Thanks for your quick answer davexnet.
Yeah, I tried it already, but that opens the dialog "Tools > apply minimum gap between subtitles..." which is not what I want.I see "apply minimum gap between subtitles"
The idea is to have these two shortcuts:
- One that assigns the "minimum gap" (as defined in "Settings > General > Min. gap between subtitles in ms") only to the current subtitle.
- One that assigns the "minimum duration" (as defined in "Settings > General > Minimum duration, milliseconds") to the current subtitle.
What I'm trying to do is to have my most used "commands" mapped to shortcuts in the number keypad.
Can I set manual starting time of all timestamps in Subtitle Edit?
By Hariachka in forum SubtitleReplies: 1Last Post: 21st Feb 2023, 15:25 -
Change minimum time between subs in Subtitle Edit
By loninappleton in forum SubtitleReplies: 15Last Post: 24th Jan 2023, 22:28 -
Subtitle Edit option to select minimum spaces between
By loninappleton in forum SubtitleReplies: 7Last Post: 19th Aug 2022, 13:51 -
Set subtitle to Zero in Subtitle Edit
By loninappleton in forum SubtitleReplies: 10Last Post: 19th Feb 2022, 16:19 -
Set subtitles to start at a specific time code using Subtitle Edit
By seorimpaek in forum SubtitleReplies: 1Last Post: 28th Jul 2020, 23:03
