Is there a good way to identify whether a clip is copied from another source video?
I have a number of source videos, say 10videos of 30minutes each, which includes audio also. I have a short video ("copied" video) which has content copied from one of the source videos. I want to identify which source video and the exact timestamp in it where this video is copied from. The short video may have modified the background blurred or hid part of the background, resized the frame from original video so it doesn't occupy all of the frame in short video, etc).
Are there any suggestions on how to achieve this using a tool/script/... ? I'm Ok with python (or C, shell script etc.).
So far, I was able to use ffmpeg to
1. Extract the audio --> Haven't found a good way to find it in original video set. Still exploring numpy and correlation, but the computation space seems massive.
2. Extract frames at every 1 second --> This would work if there is a perfect match, but I need it to be robust to image re-sizing, some blurring etc.
My guess is that if there was a way to find "motion between frames" (delta between frames taken at say, 1second intervals), and compare that for original vs. short video, I should have my answer.
Any suggestions would be welcome and appreciated!!
Note: The video doesn't have high-def content, so I can reduce the frame rate easily to reduce some computational burden.
Nope,unless you know the clip there's no way.
Need help to identify source URL to download video
By rogue2020 in forum Video Streaming DownloadingReplies: 3Last Post: 12th Apr 2023, 09:39 -
How to identify font and size of video subtitles
By magnu in forum SubtitleReplies: 14Last Post: 14th Jun 2022, 21:43 -
AVIDemux Help: How do you fix a stream copied video that goes out of sync?
By Guernsey in forum EditingReplies: 6Last Post: 14th Oct 2021, 13:54 -
Best overall picture and sound-Copied Blu-ray to 25GB or copied 4K to 50GB?
By LloydS in forum Authoring (Blu-ray)Replies: 2Last Post: 5th Jun 2019, 15:59 -
Identify the car number from a video
By Sissy in forum RestorationReplies: 0Last Post: 10th Mar 2019, 03:46
