I want to back a copy of a film on DVDr format that I made. If I want to backup this copyed can I just DVD Decrypt the DVDr to the HD and burn or will I still need to author? :P
o(-_-)o---------------------------------------o(-_-)o
if you made the copy yourself how does it escape you how to copy it again? yes, dvd decryptor will work & i see no reason why you'd need to re-author. it may or may not be faster to simply copy the files to your hdd. no idea if you can do a disc-to-disc copy on-the-fly in any burning software
It is impossible to directly copy a DVD.
1.) DVD-R General Use is 4.7 gigs, DVDs in the store r 9.4
2.) CCS prevents copying.
What you must do is rip the vobs, then demux them into there mpeg streams.
Then author a DVD-R with the streams you got from the vobs.
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 15:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 15:11 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 27th Jan 2008, 00:35 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 17:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 09:12
