Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 83
    Dec 2021
    england
    script already been post
    from pathlib import Path
    import subprocess
    import requests
    import json
    import re
    import os
    from requests.packages.urllib3.exceptions import InsecureRequestWarning
    requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
    files_to_delete = ["key.txt"]
    for file_name in files_to_delete:
        if os.path.exists(file_name):
            os.remove(file_name)
            print(f"{file_name} file successfully deleted.")
    m3u8DL_RE = 'N_m3u8DL-RE.exe'
    def replace_invalid_chars(title: str) -> str:
        invalid_chars = {'<': '\u02c2', '>': '\u02c3',
        ':': '\u02d0', '"': '\u02ba', '/': '\u2044',
        '\\': '\u29f9', '|': '\u01c0', '?': '\u0294',
        '*': '\u2217'}
        return ''.join(invalid_chars.get(c, c) for c in title)
    print(f'\ntest link: https://www.raiplay.it/video/2023/02/Mare-fuori-S3E10-Le-regole-dell-amicizia-989f9b77-c4f5-4088-952d-c8c02ce7925f.html\ntest link: https://www.raiplay.it/video/2017/10/the-tourist-5e39a1fe-71ad-44a6-bb13-aa986670bce3.html\n')
    link = input('link: ')
    link_id = re.findall(r'(https://.*).html', link)[0].strip()
    headers00 = {
        'Referer': 'https://www.raiplay.it/',
        'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36',
        'X-Caller-Version': '',
        'x-ua-token': 'null',
    response00 = requests.get(''+link_id+'.json',headers=headers00, verify=False).json()
    name_title = response00['program_info']['name']
    toptitle = response00['toptitle']
    title = f'{name_title} - {toptitle}'
    title = replace_invalid_chars(title)
    print(f'\ntitle:\n{title}\n')
    content_url = response00['video']['content_url']
    relink_cont = re.findall(r'cont=(.*)', content_url)[0].strip()
    import requests
    headers02 = {
        'authority': 'mediapolisvod.rai.it',
        'origin': 'https://www.raiplay.it',
        'referer': 'https://www.raiplay.it/',
        'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36',
    params02 = {
        'cont': relink_cont,
        'output': '64',
    response02 = requests.get('https://mediapolisvod.rai.it/relinker/relinkerServlet.htm', params=params02, headers=headers02, verify=False).text
    try:
        mpd = re.findall(r'CDATA\[(https.*?mpd.*?)\]', response02)[0].strip()
        print(f'original mpd:\n{mpd}\n')
        mpd = re.sub(r',filter=.*\)', r')', mpd)
        print(f'modified mpd:\n{mpd}\n')
    except IndexError:
        m3u8 = re.findall(r'\[(https://.*m3u8.*?)\]', response02)[0].strip()
        print(f'original m3u8:\n{m3u8}\n')
        m3u8 = re.sub(r'qual_.*/', r'qual_,1200,1800,2400,3600,5000/', m3u8)
        print(f'modified m3u8:\n{m3u8}\n')
        print()
        subprocess.run([m3u8DL_RE,
                        '-M', 'format=mkv:muxer=ffmpeg',
                        '--concurrent-download',
                        '--auto-select',
                        '--del-after-done',
                        '--log-level', 'INFO',
                        '--save-name', 'video',
                        m3u8])
        try:
            Path('video.mkv').rename(''+title+'.mkv')
            print(f'{title}.mkv \nall done!\n')
        except FileNotFoundError:
            print("[ERROR] no mkv file")
        ex_it = input('\nPress Enter to Exit...')
        exit()
    import requests
    headers03 = {
        'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9',
        'Connection': 'keep-alive',
        'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36',
    response03 = requests.get(mpd, headers=headers03, verify=False).text
    pssh = re.findall(r'<cenc:pssh>(.{20,170})</cenc:pssh>', response03)[0].strip()
    print(f'\n{pssh}')
    lic_url = re.findall(r'licenceUrl\":\"(.*?)\"', response02)[0].strip()
    print(f'\n{lic_url}\n')
    try:
        nv_authorizations = re.findall(r'Authorization=(.*)', lic_url)[0].strip()
        print(f'\n{nv_authorizations}\n')
    except IndexError:
        nv_authorizations = re.findall(r'token=(.*)', lic_url)[0].strip()
    import requests
    headers_clone = {
        'Content-Type': 'application/json',
        'Origin': 'https://wvclone.fly.dev',
        'Referer': 'https://wvclone.fly.dev/',
    json_data_clone = {
        'password': 'password',
        'license': lic_url,
        'headers': f'Connection: keep-alive\nnv-authorizations: "{nv_authorizations}"',
        'pssh': pssh,
        'buildInfo': '',
        'cache': True,
    clone_resp = requests.post('https://wvclone.fly.dev/wv', headers=headers_clone, json=json_data_clone, verify=False).text
    from bs4 import BeautifulSoup
    soup = BeautifulSoup(clone_resp, 'html.parser')
    li_s = soup.find_all('li')
    keys = []
    for li in li_s:
        keys.append(li.text.strip())
    key_s = ' '.join(['--key ' + key for key in keys])
    print(f'\nkey(s):\n{key_s}')
    print(key_s, file=open("key.txt", "w"))
    with open("key.txt", "r") as fs:
     ke_ys = fs.readlines()
     ke_ys = ke_ys[0].strip().split()
    print()
                    '--auto-select',
                    '--del-after-done',
                    mpd, *ke_ys])
    try:
  2. I tested with script with the link https://www.raiplay.it/programmi/vicinidelterzotipo , it returned some error, maybe need some fix.
    Dec 2021
    england
    play video first then get link..
    https://www.raiplay.it/video/2023/12/Vicini-del-terzo-tipo-d9346011-40d7-4995-a542-93e013157089.html
    [Attachment 75832 - Click to enlarge]
  4. great, i even not realized that the link will change when the video played. then script works, thanks iamghost.
  5. thank shellcmd for your key
    and thank also to iamghost: i've see your script but i get error like shellcmd ! with right full link to play, the script work fine. thank you both
  6. i get this error with this script before work some week ago "for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
    socket.gaierror: [Errno 11001] getaddrinfo failed"
  7. Originally Posted by me3850 View Post
    It's the same problem as the mediaset script: https://wvclone.fly.dev/wv is dead, so of course there's no server processing the license request for you to get the keys.
    Aug 2023
    sweden
    Originally Posted by thej911 View Post
    Originally Posted by SZplayer View Post
    Someone can help me and explain how get keys? What should I put in headers.py? ...
    There will be more episodes in future, so I would learn how to decrypt them on my own.
    For this , I think the "nv-authorizations" maybe of one time use , so try the following:
    - Open devtools , and go to network tab and search for lic
    - Play the episode
    - Right click on the lic url and choose "Block Request URL" then refresh the page .
    - Now the lic url "appears in red" , right click then copy as CURL (Bash) and past in https://curlconverter.com/ then copy to headers.py and it should look like this:
    headers = {
        'sec-ch-ua': '"Not/A)Brand";v="99", "Google Chrome";v="115", "Chromium";v="115"',
        'nv-authorizations': 'eyJhbGciOiJIUzI1NiI.....etc',
        'sec-ch-ua-mobile': '?0',
        'sec-ch-ua-platform': '"Windows"',
    data = '\b\x04'
    Now run the script enter the lic url and pssh and you should have your keys:
    La casa dei miracoli:
    430103a3ce9136c0b99a527e029de2af:c182a5c77df577dc03bcc2af94c0e1e6
    Un omicidio annunciato:
    1f08f0aa6eac39d5a3f62d69dae76274:fe838f5690a7bb652b5e400172b32dc5
    Regards
    I cant do it.
    When i paste this in wks-keys with code
    headers.py headers = {
        'sec-ch-ua': '"Chromium";v="122", "Not(A:Brand";v="24", "Google Chrome";v="122"',
        'x-dt-auth-token': 'eyJhbGciOiJIUzUxMiJ9.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.i1IR54l5MqMwSqwzGC91k6aR95qboLUoDDwh7UUJtrZQNNcPsK_s0O6kqkn-XFCTk-6Xl3QL8wLR_zLTPOx_aQ',
        'Referer': 'https://www.tv4play.se/',
        'Content-Type': 'application/x-www-form-urlencoded',
    params = {
        'specConform': 'true',
        'assetId': 'tvmedia-20470088',
    data = '\b\x04'
    response = requests.post('https://lic46.drmtoday.com/license-proxy-widevine/cenc/', params=params, headers=headers, data=data)
    And nothing happend if i only write headers.py and press enter.
    I dont understand whats wrong
  9. headers.py looks like this:
    headers = {
    params no need, it usually follow license url. // if you want to use it from headers.py, you need send params=headers.params
    data=xxxxxx, no need, it comes from CDM.
    response=xxxx, no need.
    delete all no need part.
    Aug 2023
    sweden
    headers = {
    I write cmd in the path where i have headers.py and after that write the code
    headers = {
    But its not work. Maybe i do something wrong.
  11. then there are something to attention:
    1.the token maybe expire fast or just one time used, so you need copy paste as fast as you can, or block license request, get a no used token.
    2.use correct license url, it should looks like
  12. Hi, for raiplay you need the PSSH and as headers only the Nv-Authorizations
    example
    # send license challenge (assuming a generic license server SDK with no API front)
    licence = requests.post("https://lic.drmtoday.com/license-proxy-widevine/cenc/", data=challenge,
    headers={"Nv-Authorizations": "eyJ0aSI6ImZjMDc4MzJmODdiNjc5NDk1MTk2ZGJkZjMwZGYxY jgxIn0="}
    lasts only a few seconds 15 or 20 at most.
  13. Originally Posted by Goku73 View Post
    example
    Hi, I did as you said, but it keeps giving me this error
    [Attachment 79926 - Click to enlarge]
    https://www.raiplay.it/video/2024/06/Calcio-Euro-2024---Fase-a-gironi-Italia-Albania--...8fe673a39.html
  14. Member aqzs's Avatar
    Mar 2024
    Paris
    You didn't put the license url in the field and put the header in the license url field.
  15. Image
    [Attachment 79931 - Click to enlarge]
    I found the keys, but he still downloads it with protection
  16. Originally Posted by supergirl73 View Post
    The two KIDs do not match, you have the wrong video, try this link it should work, the key is right
    https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Euro_2024_multiaudio/23538280_,1800,2400/manifest_mvnumber.mpd
  17. Originally Posted by Goku73 View Post
    I tried with your link, but it doesn't work
    the kids come the same as before
  18. Member aqzs's Avatar
    Mar 2024
    Paris
    mpd url (will expire):
    https://streamcdnr12-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Euro_2024_multiaudio/23538280_,1800,2400/manifest_mvnumber.mpd?hdnea=st=1718626429~exp=1718626579~acl=/*~hmac=482139315e3103f8b348bbb613f3071a189dac2d46310aee2ae5b46745f4b3ed
    pssh :
    AAAAd3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFcIARIQeaGy6B22M9aNpzGJZrjonhoFTmFncmEiOmRybV9yb290L0RSTU5hZ3JhX0V1cm9fMjAyNF9tdWx0aWF1ZGlvLzIzNTM4MjgwXywxODAwLDI0MDA=
    key :
    79a1b2e81db633d68da7318966b8e89e:fab0cef39f66dbfd78b9f7cba53ff010
    command :
    N_m3u8DL-RE --key 79a1b2e81db633d68da7318966b8e89e:fab0cef39f66dbfd78b9f7cba53ff010 "https://streamcdnr12-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Euro_2024_multiaudio/23538280_,1800,2400/manifest_mvnumber.mpd?hdnea=st=1718626429~exp=1718626579~acl=/*~hmac=482139315e3103f8b348bbb613f3071a189dac2d46310aee2ae5b46745f4b3ed" -M mkv --save-name "Italia-Albania"
    your file : https://www.swisstransfer.com/d/f27e939d-c2d7-43b2-a170-11b70c6713e5
  19. Originally Posted by supergirl73 View Post
    It works perfectly, you must have copied the link wrong.
  20. Originally Posted by Goku73 View Post
    ok, thanks everyone
  21. https://www.raiplay.it/video/2024/07/Calcio-Euro-2024---Quarti-Spagna-Germania---05-07...b37ef2931.html
    good morning, I can't understand why the two kids don't match, I think the call is right
    [Attachment 80451 - Click to enlarge]
    in the previous post they told me that the key was right, but the video link was wrong, I saw that it changes continuously, but I can't put the right one
  22. the key is right, but maybe it is for 720p not for 1080
  23. kids are not the same
    it's the same key I used
  24. Originally Posted by shellcmd View Post
    for 1080p what should I do?
  25. lol buy L1 cdm (about 400$)
    or dump your L1 from your phone. read sticky thread about how to. good luck
    or maybe, more easy, be happy to 720p
  26. so the 1080 file can be downloaded, but not decrypted?
  27. Member aqzs's Avatar
    Mar 2024
    Paris
    L1 will not help to get 1080p. If you got 'UNGRANTED_REQUEST' it's because the nv-authorizations in the header only works for 720p.
  28. the 1080 file lets me download it, but it doesn't decrypt it
  29. L3 is enough for 1080p only the process to get it is not straightforward
    720p key
    13b558b9e5cb3b969a4e25599d23623f:592141775a6b56f1caf0af030f3fd538
    1080p key
    20d5b1c51a47308c8df76565e81978d1:043d94a1b571d554c75fc08ffb4c3cc9
    if that doesn't work with your link try this one:
    https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Euro_2024_multiaudio/23696486_,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1720294810~exp=1720294960~acl=/*~hmac=acd99f939c12920c74a0eb12d5db68dbf81f2f182a99e15f8adad34febecdfda
