I use Avidemux for basic editing (cropping, splicing, tweaking audio tracks, etc). It works great, but it does not support HDR.
Are there any similar tools that can import an HDR HVEC (YUV420p10) then it allows me to encode it at 10 bit HDR (YUV420p10) with placebo preset and my desired bitrate?
So far the only tool Ive found is handbrake (which is limited in usage, and does not have a UI like Avidemux). Seems all other software ive tried either does not support it, or its only available in the expensive paid version.
Sorry, but no clue, but you might want to specify the flavor of HDR (HDR10, HDR10+, Dolby Vision) are you aiming for to let others know
For HDR10 you could use Avidemux for editing, export to a lossless format and then reencode the video with a tool which allows you to set the HDR meta data when encoding to HEVC.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I think most videos I have are HDR10.
I'm not too familiar with any of the technical details on HDR. I did try encoding to huff (in avidemux), then loading that file into handbrake and re-encoding at HEVC 10 bit with bt.2020 color space (to match original). But this failed. I'd imagine following your suggestion id need to load the original into MediaInfo and somehow find another encoder that I can plug those number in? If that is the case, got any recommendations?
And if this lossless trick does work, then in theory couldn't I also use something like the free version of 'DaVinci Resolve' to load my lossless file, do some fancy editing, save as lossless, then reencode to HDR with the metadata from the original file? -
You can use clever FFmpeg-GUI.
Related Features:
Recode from HDR10+ to HDR10+ (e.g. resizing).
Recode from HDR10+ to SDR while preserving colors.
Authoring 1080p 10 Bit H.265
By C.C. 95 in forum Authoring (Blu-ray)Replies: 23Last Post: 3rd Dec 2024, 22:39 -
Any truly Free programs to edit HVEC .265 video?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 31st Aug 2021, 09:40 -
Any Video Converter - H265 10-bit HDR
By tmohr in forum Video ConversionReplies: 1Last Post: 15th Mar 2021, 09:22 -
10-bit to 8-bit Video File Conversions - the easy (free) way!
By VideoWiz in forum Video ConversionReplies: 10Last Post: 6th Feb 2020, 03:24 -
HDR video editing
By winoni71 in forum EditingReplies: 0Last Post: 19th Aug 2019, 08:36
