Tell me how to export external encoders to Avidemux and VirtualDub2. Especially important for VirtualDub2, it has old versions of codecs. Interesting x264 and x265 codecs. Probably it will be FFMPEG codecs.
just curios, since I haven't used VirtualDub&Co for 10+ years,...
Doesn't VirtualDub2 support external encoders the same way VirtualDub did?
(https://forum.videohelp.com/threads/367446-Virtualdub-External-Encoder-feature)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Thank you. I will try it. But the instructions at the beginning of this topic show importing a project with codecs, but not adding an encoder.
I now thought. VirtualDub2 is probably an old application. What is the best modern application to use for downloading Avisint scripts and video encoding?
In addition to it's built in encoders VirtualDub2 can use system installed VFW codecs. So install a VFW encoder if you want to use the original or VirtualDub2 for encoding. Or just use some other program for encoding.
I typically use VirtualDub2 to view/edit my scripts, then use the x264 command line encoder or ffmpeg to encode them (via a batch file). Some like to use AVSPMod for both. -
Thanks for answers.
VFW codecs are probably not new either. And by the way, it is not clear how to select an audio codec in VirtualDub2 when saving a video. Apparently, you can't do without adding external encoders. Perhaps the best use of VirtualDub2 with Avisynt is frameserver. But for a beginner it will be difficult.
Can't use VirtualDub external encoders and can't figure out why
By Bruce Banner in forum Video ConversionReplies: 3Last Post: 11th Sep 2021, 09:24 -
AVIDemux: Is it good Virtualdub2 alternative?
By Guernsey in forum Newbie / General discussionsReplies: 10Last Post: 20th May 2021, 18:42 -
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 05:25 -
Need help finding external encoders for VirtualDub2
By Bruce Banner in forum EditingReplies: 4Last Post: 11th Aug 2019, 19:10 -
How to add external encoders to VirtualDub2?
By pernicio in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2019, 15:45
