I need help bad. Im trying to author a dvd. Im putting 5/12 hours of mpeg 1 video on the dvdrw. The file are broken up into 5 one segments and 1 half hour segments. Well when Im through with with the project and try to play on my pc or standalone, the picture stops at EXACTLY at 20 minutes into the movie and the audio continues. If you click to the next file it does the same thing. Starts off fine and insync and then 20 min...it goes all to hell. Can someone help me please. Ive been going at this for 2 weeks. Cant figure it out. If Dvd Workshop cant encode correctly after 20 min. I will badmouth this program as long as I can.
Thank in advance. :roll:
hey badmouth, have yuou downloaded the beta patch for audio synch for it ?
try it
DVD Workshop 2 - No Audio in Windows 7
By KTH in forum ComputerReplies: 3Last Post: 27th Dec 2010, 16:08 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
DVD Workshop 2: Where is the best tutorial for this project?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2010, 09:09 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
