What would be the best way to compress videos to save space without losing any video quality??
Would going with H265 be a good option for this and on average how much space would I save with going with H265 over H264 at the same bitrate??
Results 1 to 24 of 24
You can't do it without loosing quality.
h.265 potentially can compress the video about 30 percent better than h.264. Exactly how much better depends on the particular video, the particular encoder, and the particular encoder settings used. -
Would it be worth it convert like 10tb to 15tb worth of video to H265??
Originally Posted by Djboutit
False, and not appropriate, Handbrake is just a GUI
So which of these two would be better for saving space H265 or AV1 10bit??
In theory, AV1 is better. But AV1 is generally slower by quite a bit. And there's not much playback support outside of computers yet.
Generally, faster encoders deliver lower quality or require more bitrate to achieve the same quality. So by asking for fast encoding you're getting worse quality and/or larger files.
That said, what's fastest depends on your hardware and the settings you use. Does your graphics card (or integrated GPU) have a hardware h.265 encoder or AV1 encoder? Try comparing the hardware encoder to software encoding with your CPU. For example NVEnc h.265 (nvidia's hardware encoder) vs. x265 (an open source software encoder). There are very few hardware AV1 encoders as of yet. Recent builds of Handbrake give you access to all these encoders.
But basically, I consider it a waste of time and resources to convert h.264 to h.265. -
Handbrake is not an encoder, so the statement from user Santiango saying "is a free program that reduces video size without any loss of quality." does not make any sense.
The encoders supported by Handbrake make, or better, make not, the reduction of size without loss of quality. -
https://www.newegg.com/asrock-arc-a380-a380-cli-6g/p/N82E16814930076?Item=N82E16814930076
https://www.tomshardware.com/reviews/intel-arc-a380-review/5
I know you expected different answer but as you not providing information about your current setup then from my perspective this is most sane approach unless you willing to wait many hours.
Btw i would recommend A310 but it seems to be not available to buy. -
@OP
You are going about things the wrong way.
Once something is in a delivery format, h264, h265, vp9, av1, etc, it is nearly always best to keep it in the format it currently is.
If you shop around you can find 512gb thumb drives for $35; buy 2 of those and call it a day:
https://www.microcenter.com/product/658941/micro-center-512gb-superspeed-usb-30-flash-drive
What can I use to compress a webm file without losing transparency?
By supercain in forum EditingReplies: 17Last Post: 24th May 2022, 19:59 -
How to compress video vertically/horizontally in Daum Pot Player
By DragonChasm in forum Software PlayingReplies: 4Last Post: 5th Dec 2021, 05:04 -
Losing Signal While Capturing Video From Old Tapes
By dakotasamuel in forum Capturing and VCRReplies: 27Last Post: 12th Apr 2021, 08:37 -
What is the best way to compress multiple large video files.
By Pepy in forum EditingReplies: 0Last Post: 21st Mar 2020, 13:15 -
Best way to compress large Video Files (HandBrake, MP4)?
By user115 in forum Video ConversionReplies: 21Last Post: 17th Dec 2018, 09:04
