I've recently switched from capturing with an older ATI card to using Hauppauge USB-Live2 and I find the noise at the boundaries of high contrast areas or around fine details/text on EP tapes to be significantly more noticeable. Are there any best practices AVISynth scripts to help minimize this issue post-capture?
Maybe is not at issue by itself, but more "data" captured. Be sure there is no oversharping halo. You can reduce the noise with a temporal or a spatial/temporal denoiser, like TemporalDegrain2 or similar
edit: remember to use USB-Live 2 with Y/C input! -
In my experience dot crawl artifacts from different capture devices/sources can require very different methods. It's best if you upload a sample.
Looking for 3D comb filter capture card for Laserdisc
By pthebest19 in forum Capturing and VCRReplies: 70Last Post: 18th Apr 2023, 05:45 -
Avisynth reviving old scripts
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 24th Dec 2021, 10:05 -
What is a good way to practice using AVISynth and FFMPEG scripts?
By Guernsey in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2021, 12:51 -
Looking for a VCR with a good comb filter
By TheRealOC in forum Newbie / General discussionsReplies: 0Last Post: 16th Dec 2020, 04:30 -
Multi-format VCR player with good comb filter
By TheRealOC in forum Newbie / General discussionsReplies: 16Last Post: 7th Dec 2020, 23:03
