Hi everyone,
I'm just posting this question as I'm a Davinci Resolve user on Mac and I've started experiencing work flow issues when I go beyond just editing and grading. While I do edit 4K footage, it's in a 1920 x 1080 HD Timeline resolution, I also use proxy footage and I'm editing that footage from a Sandisk Extreme Portable SSD drive.
I'm wondering what the next step / upgrade is that I should think about, as I'm experiencing a lot of slowing down once I implement things like grading along with effects, masking and transitions etc.
My setup currently is:
iMac (Retina 5K, 27-inch, 2019)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 96 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8 GB
I do anticipate that I'll be doing alot more than just editing and grading, so any help would be greatly appreciated! I've been doing a bit of research but still don't know whether I need a new graphics card or processor etc?
Thanks,
Al
Cheers for the response Subtitles. Yeah it appears to be SSD for what ever that's worth!
The only problem is quite like the general workflow of being able to do everything inside DR without having to roundtrip to Adobe Premiere and vice versa.. but it just seems strange that it's lagging this much despite having not that many transitions, effects and nodes when grading. -
Which version of DR are you using? Latest is 18.5
Is it the free version or Studio? -
Please update to latest version. I hate to suggest to spend more money on another software, but the free trial would tell you if it is software related.
Of course you can always ask for support from the developers they might give you new ideas or solutions.
Downloading videos from Jiocinema : Step by Step Guide
By sarvo99 in forum Video Streaming DownloadingReplies: 4Last Post: 23rd Mar 2024, 03:47 -
step by step m2p to DVD
By bitofmorethanicanchew in forum Newbie / General discussionsReplies: 46Last Post: 17th Oct 2021, 01:55 -
Is there a way to make these lines smoother?
By blitzgrey in forum EditingReplies: 5Last Post: 11th Jul 2020, 08:33 -
VirtualDub Chroma Smoother
By jseo13579 in forum EditingReplies: 12Last Post: 12th Jul 2019, 21:56 -
AviSynth Smoother
By jseo13579 in forum EditingReplies: 7Last Post: 21st Mar 2019, 09:07
