hi,
i have .avi files thet i was make in premier after i capture them from my Sony DV Camcorder.( the files are in DV-1 format )
now i want to convert them to mpeg-2 useing TMPGEnc to Burn them in to my new Pioneer DVR-A04. but avry time i tria to open the fils ib TMPGEnc i gut this error "file "test.avi" can not open ,or un supported".
I find help in the convert guide thet say... " If you have problem open DV video, DC30+,MJPEG captured video or any AVI VFW
Then try to change the settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the AVI VFW and increase the priority to 1 and try open the video. " but it's won't help......
plase help...
thanks.
Convert HDTV ts files to DVD mpeg or Avi
By kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 10:17 -
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 06:29 -
Convert TS/TS4 files to avi or mpeg
By Borg in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 21:11 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Can I convert BD .mt2s files to MPEG-4 AVC/H.264 using TMPGEnc 4.0
By EdinburghKev in forum Blu-ray RippingReplies: 3Last Post: 20th Nov 2008, 10:10
