Results 1 to 9 of 9
    Mar 2018
    Australia
    I have ripped a DVD with VLC, Handbrake, WinX DVD Ripper and VideoProc and each stops short of the end by several minutes. Is there a remedy ?
    Mar 2021
    Israel
    StreamFab has several DVD software.
    DVD Ripper
    Blu-Ray Ripper
    They are not cheap but at least you can try them (Free trial available not sure about limitations) and see if they give you a better ripping.
    Mar 2018
    Australia
    The four I mentioned managed to rip more than 95%; Streamfab crashed in the attempt.
    Mar 2021
    Israel
    Just proves the saying "best things in life are free".
    Mar 2021
    Israel
    Is the DVD finalized? Can you use another DVD player?
    May 2005
    PAL User
    MakeMKV.
    If you want one single file of the movie use Save Selected Titles.
    If rip want to rip the whole disk to ISO use Backup.
    Mar 2018
    Australia
    DVDShrink copied the DVD to files, without truncating the end - however the files are a number of VOBs, which I would want joined into a single video file.
    May 2005
    PAL User
    Use AVIDemux to join up your VOBs into one MPEG 2 file.
    I have written a guide here:
    http://aaproductions.net/avidemux.htm
    Note, it doesn't need to be "installed", download the "Portable" version, unzip and run the exe file. Follow the initial bit, then down to the Combine Multiple VOBs into a single MPG.
    Mar 2018
    Australia
    Thank you.
    It so happens that my usual movie joiner MOVIEMAKER could do the job of joining just the video VOBs with the result of an mp4 file that has sound-track.
