hello, I have a blu ray movie divided into 2 discs, from those discs I made an mkv file with make mkv but when I put them together with mkvtoolnix they create 2 seconds of a black image, without sound without video, is there a way to configure mkvtoolnix so that this does not happen when joining separate Blu-ray discs? Another question, is there a way to remove those black seconds without rendering or how can I remove it with mkvtoolnix?
	You can't do frame accurate edits with mkv files unless you re-encode. Cutting or joining mkv files can only occur on I frames unless re-encoding. SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	What is meant by "they" ? You mean the software or your player(s) or...
 If the few seconds with black and no sound is a part of the source video - at the end of part one, or the beginning of part 2 - at least smart-rendering (re-encoding only at joining point) is necessary, as netmask56 already stated. Where audio can raise issues too. Having no sound can point to silent audio being present.
 Small chance the 2 seconds are created by the player. Where trying another one may help out.
	Remux both mkv to ts and join the two ts files.
 Then remux the joined ts file back to mkv.
 You can use clever Ffmpeg-GUI for this steps.
  Colorizing black & white movieBy Roméo Latour in forum RestorationReplies: 75Last Post: 15th Mar 2024, 12:50
  Video Split / Right Hand Side Black Box IssueBy tangerine7 in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2021, 08:59
  Video Split Does not split at exact pointBy Nothingissimple in forum EditingReplies: 2Last Post: 2nd Oct 2020, 21:58
  Joining files with MKVToolnix failedBy raulpuro in forum Video ConversionReplies: 4Last Post: 11th Jul 2020, 07:08
  Joining MKV with subs in multiple languages with MKVToolnixBy Tedbax in forum EditingReplies: 4Last Post: 3rd Mar 2019, 04:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
