Here is the spec for ITU BT.2111, the specification for HDR color bars.
https://www.itu.int/rec/R-REC-BT.2111/en
Having worked in transmission for many years, I can tell you that standardized color bars are still quite useful.
The upper strip of the color-bar signal is 100%; the remainder is 75%.
Below are some sample 10-bit values taken from TABLE 2 of the spec (R-G-B):
100% White: 940-940-940
75% White: 721-721-721
100% Yellow: 940-940-64
75% Yellow: 721-721-64
0% Black: 64-64-64
-2% Black: 48-48-48
+2% Black: 80-80-80
+4% Black: 99-99-99
For setting monitor brightness make the +2% and +4% bars "just visible".
Results 1 to 1 of 1
HDR experience - Win7 + HDR map + HDMI 1.3 vs. Win10/11 + HDR + HDMI 2.0
By bloodhand in forum Software PlayingReplies: 4Last Post: 17th May 2023, 17:13 -
HDR video to standard Blu-ray
By frodawgg in forum Video ConversionReplies: 5Last Post: 16th Jul 2021, 11:26 -
HDR Video Color
By forsure in forum Newbie / General discussionsReplies: 21Last Post: 25th May 2021, 22:31 -
Restore HDR Color settings in Windows 10
By forsure in forum ComputerReplies: 62Last Post: 29th Mar 2021, 18:19 -
Inquiry on hdr color 4k tv
By K.S.LEE in forum Newbie / General discussionsReplies: 4Last Post: 16th Nov 2018, 21:44
